I recently installed a magnetic drain plug after doing my first oil change. Do these things really work, or are they more of a gimmick? I was also thinking about installing a Stahlbus drain valve next time, since I plan on doing a couple oil changes prior to my 600 mile service. I know removing the stock plug isn't a big deal, but I like the fact the Stahlbus is a one time install, and won't have to worry about the possibility of stripping the oil pan threads, even though I don't go near the 31 ft/lb spec. Anyone using the Stahlbus, whats your thoughts on it? How well does it work? How do you experienced any leaks with it? I'm just trying to decide whether to stay with the magnetic plug or replace it with the Stahlbus. I appreciate any advice you can give me.
I had magnetic plugs on my engine and tranny for my '08 Civic Si. Always was dirty after every fluid swap. I have a valve on my Silverado which has never leaked, but went with magnetic on the bike.
I'm thinking I'll use the magnetic plug during the break in period, just to help with catching any metal bits in the oil. Then switch over to the Stahlbus later. That is unless I notice the magnetic plug not catching anything, at which point I'll change over to the Stahlbus immediately.
Just get the Stahlbuse and be happy, like mentioned above ..... A few times :sly:
I would wait for your oil change thow, no sence in wasting good oil and a crush washer..lol
Soooooo, did you ride it yet John?
Related Threads
3.1M posts
112.1K members
Since 2003
