Blow out on PC3's - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
post #21 of 36 (permalink) Old 11-07-2011, 01:57 PM
The GodFather
SpidermanSS's Avatar
Bike: R1 - R6 - YZF's
Images: 3
Re: Blow out on PC3's
I have 5 in stock for the 07R6... (non S)
YAMAHA EVERYWHERE!
TEAM: SO FAST SO CLEAN
KILO 3483 I miss YOU! In Memory of : fastblueR1 : K_FleXXX : GLENN "ELVIS" : Gawarrior I miss YOU!
Twitter: @SpidermanSS
SpidermanSS is offline
post #22 of 36 (permalink) Old 11-07-2011, 05:09 PM
tuscanijon's Avatar
where do I order?
tuscanijon is offline
post #23 of 36 (permalink) Old 11-07-2011, 05:53 PM
The GodFather
Images: 3
Call 678-354-3730 8-5 eastern and ask for the PC3 special.
YAMAHA EVERYWHERE!
post #24 of 36 (permalink) Old 11-08-2011, 08:39 AM
The GodFather
Images: 3
Thanks for the order...
YAMAHA EVERYWHERE!
post #25 of 36 (permalink) Old 12-08-2011, 05:45 PM
Bump... I still have some left
DEMPSEYRACING is offline
post #26 of 36 (permalink) Old 02-08-2012, 12:00 PM
Pobrecitos
Mac7504's Avatar
Bike: 08 R6S + 08 R6LE
Man, I totally spaced on this deal...Any left for an 08 R6S?
Mac7504 is offline
post #27 of 36 (permalink) Old 02-08-2012, 12:04 PM
The GodFather
Images: 3
Yes there is one left you can call Skip toll free at 855-994-0990 to order.
YAMAHA EVERYWHERE!
post #28 of 36 (permalink) Old 02-08-2012, 01:56 PM
Pobrecitos
Mac7504's Avatar
Thanks for the quick response, I do, however, have a question; should I ask to have the Map preloaded as you suggested in your previous post here?
I know you said to ask for a Graves slip on and I could load whatever I wanted later.
I'm running a yoshi slip, will the Graves work to get me going, until I get it properly dyno'd? or should I just load what I have (having a hard time finding a Yoshi map.
Mac7504 is offline
post #29 of 36 (permalink) Old 02-08-2012, 02:04 PM
2007 r6
Adriel's Avatar
Bike: 2007 Yamaha R6
What is the difference between the power commander 3 and the power commander 5
Adriel Araiza
Red 2007 r6
Adriel is offline
post #30 of 36 (permalink) Old 02-08-2012, 02:22 PM
GRAVESPORT.com's Avatar
Bike: 09 R/6, 92 GSXR 750,
Adriel Araiza
Red 2007 r6
basically this.....
■Reduced size from PCIIIusb (less than half of the size of PCIII)
■USB powered from computer (9 volt adapter is no longer needed for programming)
■2 position map switching function built in (map switch not included)
■Gear input (allows for map adjustment based on gear and speed)
■Analog input (allows user to install any 0-5 volt sensor and build an adjustment table based on its input such as boost or temperature)
■With gear position input connected the PCV is capable of allowing each cylinder to be mapped individually and for each gear (for example: on a 4 cylinder bike with a six speed transmission there could be up to 24 separate fuel tables).
■Unit has a -100/+250% fuel change range (up from -100/+100%). This allows more adjustment range for 8 injector sportbikes
■10 throttle position columns (up from 9 on PCIIIusb)
■Enhanced “accel pump” utility (increased adjustment and sensitivity ranges)
GRAVESPORT.com is offline
Super blow out OutRun McCoy Motorsports 1 09-15-2011 09:52 AM
Super blow out OutRun McCoy Motorsports 0 09-15-2011 09:20 AM
blow out OutRun McCoy Motorsports 0 02-17-2011 03:22 PM
Did I blow it? ryan General Discussions 10 12-04-2006 05:35 PM
