Graves R6 Garage - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
post #21 of 60 (permalink) Old 08-24-2009, 04:47 PM
Living between the cars
deadwood's Avatar
Bike: '08 R6
Re: Graves R6 Garage
Taige,
I tried emailing you but it came back as an invalid address. I have a question well 2 actually. The map you sent me was that for a full exhaust or slip on? I have a slip on right now currently saving for the full system. Second I installed my block off plates and the map you sent. My exhaust now has a strong fuel smell. Could this be due to the block off plates or the map?
Thanks in advance.
deadwood is offline
post #22 of 60 (permalink) Old 08-27-2009, 09:45 AM
deadwood's Avatar
Bike: '08 R6
bump
deadwood is offline
post #23 of 60 (permalink) Old 02-23-2010, 01:28 AM
BluebyU55's Avatar
Bike: Yamaha R6
hey guys how are you hope all is well .... last week i got lucky and bought Michaels Becks 08 Yamaha Graves R6 for great price and im going to race it WERA or WSMC this year before i start racing i am looking for a graves mechanic to take a look at the bike for any problems im sure he brought the bike to you guys and im sure name Toki sounds familiar to you right LOL ... is there a mechanic that you can reefer me to or i need to bring it to your shop i dont live to far away from you guys so it wont be issue to me to drive by and talk to you guys ...
thanks for any info you can relay to me
BluebyU55 is offline
post #24 of 60 (permalink) Old 03-05-2010, 02:16 AM
R6'er
Raider 1's Avatar
Images: 3
Is there anywhere I can go for instructions on how to repack GRAVES muffler and do you have any replacement materials for them? Thank you, mark
Raider 1 is offline
post #25 of 60 (permalink) Old 08-27-2010, 04:45 PM
I'm having a problem with my 04 R6. It has 9K miles and only a Devil high mount pipe. I took the bike out for a ride and when I was at a light about to pull away I stalled(I just didn't give it enough gas). I started the bike back up and immediately noticed the change in the exhaust note, very deep, almost sounds like a Ducati. The bike also has no power and barely any throttle response. I started to visually inspect for anything obvious but couldn't find anything so I started taking off some stuff. I just got done installing your block off plates, new plugs and I also put in new fuel, then disconnected the battery. I figured I'd change the plugs while I had them out but I wasn't really expecting it to fix it and it didn't hah. The bike still runs awful and has no power.
Any thoughts?
Grifter371 is offline
post #26 of 60 (permalink) Old 09-08-2010, 08:32 AM
The GodFather
SpidermanSS's Avatar
Bike: R1 - R6 - YZF's
Images: 3
You can check to see if you installed the smog plates so that they seal the block correctly. They just remove the emissions setup for racing though and wouldn't change anything else.
Re-check the plugs since you recently changed them. From there un-hook the power commander if you have one just to check. At the point your engine would need to be looked at... GOOD LUCK.
YAMAHA EVERYWHERE!
TEAM: SO FAST SO CLEAN
KILO 3483 I miss YOU! In Memory of : fastblueR1 : K_FleXXX : GLENN "ELVIS" : Gawarrior I miss YOU!
Twitter: @SpidermanSS
SpidermanSS is offline
post #27 of 60 (permalink) Old 09-08-2010, 08:53 PM
I meant update my post. I had a bad ignition coil which was causing a constant misfire.
post #28 of 60 (permalink) Old 10-06-2010, 02:06 PM
Mr R6 p0wns me
Bike: 15 R1
Send a message via AIM to signalbobby
Does graves has replacement exhaust can tips? I have the full titanium system and would like to replace either the entire titanium can or just the tip and rivets. and is this doable?
-) Signal Soldier (-
signalbobby is offline
post #29 of 60 (permalink) Old 10-06-2010, 02:09 PM
The GodFather
Images: 3
You will have to call our California office at 818-902-1942. The can will need sent to use and we can quote you on replacing the parts if things aren't damaged enough to fix it.
YAMAHA EVERYWHERE!
post #30 of 60 (permalink) Old 02-01-2011, 08:09 PM
Hey all, I'm in the process of ordering GRAVES Rearsets for my '09 R6, will I still be able to have brake light functioning with the kit installed? Will I need an additional part to get it to work? Thanks -Bryan
bry_671 is offline
Graves Fender Eliminator R6 03-05 ZipPhReaK Bike Parts For Sale 5 09-08-2008 05:24 PM
Random R6/GSXR parts, rearsets, takesoffs, new tires, ect... FastrnU Bike Parts For Sale 24 09-07-2008 02:57 PM
Performance and stock from 03 R6 power commander w/quik shift, Graves, vortex, Scotts trboboostr6 Bike Parts For Sale 9 07-28-2008 07:15 PM
WTB: Full graves for a 07 r6. xlversatilelx Bike Parts For Sale 0 05-01-2008 07:53 PM
Pics of Graves shorty's on 06 R6? Other suggestions? Speed_Addict Appearance and Exterior Mods 16 03-25-2006 01:25 PM
