Bryant's 2000 R6 - Page 12 - Yamaha R6 Forum: YZF-R6 Forums
post #111 of 132 (permalink) Old 12-08-2012, 07:21 PM Thread Starter
Go Fast or Go Home
Bike: 2000 Yamaha R6
Re: Bryant's 2000 R6
yea id prolly just use them as running lights prolly. maybe it would look cool with red LED bulb on your bike and blue on mine
2000 Yamaha R6 17,xxx miles. Carbon fiber pieces. DanMoto Carbon GT exhaust. 6k HIDS. Integrated tail.
BBudensiek is offline
post #112 of 132 (permalink) Old 12-09-2012, 05:13 AM
bgballin26's Avatar
Bike: 1999 R6
If i could get my flush mounts to actually work as flashers i would, but when i hook them up they don't flash, and the flashers on the intrument panel won't flash either, i can't figure out what the problem is. If i hook 1 side up, and leave the other side hooked up to the stock flasher, the led flush mount will flash. Maybe i should try different flashers, i was told the CustomLed flasher relay would fix the problem but it didn't.
99 r6 ~ Factory Pro Jet kit with slight changes, OEM filter, TSR Frame Sliders, Dan-Moto Carbon Fiber GP exhaust, Renthal grips, JPR levers, pro tek bar ends, motion pro cables, Michelin Power 2ct tires, RK 520 conversion -1/stock rear, headlight signal conversion using 2003 r1 sockets, Luckybike.com flushmounts used as running lights, Puig double bubble windscreen
bgballin26 is offline
post #113 of 132 (permalink) Old 12-09-2012, 07:34 AM
Yeah Science!
wutsup's Avatar
Bike: gixxer chrome edition
^Why is your sig so big?..
Chris
06 GSXR 750
08 Track R6 RIP
wutsup is offline
post #114 of 132 (permalink) Old 12-09-2012, 08:08 AM Thread Starter
Go Fast or Go Home
have you tried the load equalizer bg? Either this
http://www.customled.com/products/lo..._equalizer.htm
or i got this... so my greggs flush mounts work as runnig lights and blink when i turn the flasher on...
http://www.customled.com/products/ma...ic_blinker.htm
post #115 of 132 (permalink) Old 12-09-2012, 12:55 PM
bgballin26's Avatar
Bike: 1999 R6
Every since photo bucket changed i haven't been able to figure out how to make the picture smaller.
I have not tried the equalizer's but i will
post #116 of 132 (permalink) Old 12-09-2012, 06:51 PM Thread Starter
Go Fast or Go Home
i had almost the same problem that you had bg and i got the equalizers and it fixed it
post #117 of 132 (permalink) Old 12-09-2012, 09:07 PM
bgballin26's Avatar
Bike: 1999 R6
I'm going to tear my bike apart now that it's cold, i will try them out and see if it works, if it does i will use my r1 sockets as running lights, and i'm thinking about going back to the stock headlights, the hid's for 1st gens are way too bright, it's even bright with just 1 hooked up.
post #118 of 132 (permalink) Old 12-10-2012, 06:51 AM Thread Starter
Go Fast or Go Home
yea hopefully it fixes it!. What are you doing to your bike?
post #119 of 132 (permalink) Old 12-10-2012, 09:57 AM
bgballin26's Avatar
Bike: 1999 R6
I'm going to replace the mixture screws on the carbs because the rubber o-ring is bad shape, and turn them out to 2 turns to see if it helps my idle problem, also going to change the plugs, flush the coolant and change the thermo sensor because my fan won't kick on, but it works if i put it on a switch. I think my valves are loud but i had someone tell my that r6's have noisy valves, but i might check them anyways. Also need a new clutch.
post #120 of 132 (permalink) Old 12-10-2012, 01:22 PM Thread Starter
Go Fast or Go Home
Yup thats my sprinmg project... jet carbs, and also are your mixture screws at factory adjustments? or have you messed with them? I wish i could get to my bike but its in storage til spring and also i got some visual mods im going to do i cant wait just to see what the jet kit will do! im going with a factory pro jet kit as well... is it difficult to figure out what setting to use? Bcuz im not looking forward to trying one than taking it all back apart to try another setting... lol id like to get it set right the first time
2000 YZF R6 Race Prep - $2000 tsd345 Bikes For Sale 0 05-30-2012 06:43 PM
FS: 2000 - R6 - Black - $2000 - 7000 miles - Michigan somewhere spdrace11 Bikes For Sale 2 08-02-2011 04:03 PM
FS: 2000 - R6 - Champions Edition - $2000 OBO - 30,000 miles - Washington Illernoise Bikes For Sale 14 11-21-2010 10:03 PM
FS: 2000 - R6 - Blue - $2000 - 32,000 miles - Albany, Oregon yotaismygame Bikes For Sale 1 05-21-2010 08:31 PM
Kobe Bryant spooknickr6 Off Topic Talk 33 06-17-2009 01:56 PM
