When Will My Motorcycle Battery Die? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 1 (permalink) Old 02-22-2017, 12:50 PM Thread Starter
It depends where the bike lives: Hot and cold climates are both harder on batteries than temperate climes, and bikes that get ridden regularly are easier on batteries than ones that sit for months – though a good battery tender with a float feature negates much of that. In fact, I was bragging about the
in my bike not long ago, which must be seven years old now and has never seen a charger, when my friend Jim said big deal, the original equipment sealed
in his VFR lasted 9.5 years, and his 21-year old
is only on its second battery. So, sealed batteries can last a long time especially if you’re OCD about maintenance.
According to several sources including
, though, your 12.3-volt reading means your battery may be on its way to Nirvana; a fully charged one should read 12.7 volts or above. Since you like to play with your voltmeter, there are instructions to “stress test” your battery at the same page, along with a lot of other battery tidbits that will let you know for certain if it’s time to replace.
Send your moto questions to
. If we don’t know the answer, we know who does, and if they don’t know we’ll make up something reasonable-sounding. What do you want for free?
Read more about
at Motorcycle.com.
Motorcycle.com is offline
Will the Battery die? MotoQ80 General Discussions 2 05-28-2014 05:36 PM
So you want to ride a motorcycle and not die Jeff9965 Safety Equipment 6 03-24-2012 06:10 PM
HID's causing battery to die or bad stator etc? HELP jtmcfad Garage / Mechanical Help 9 12-06-2009 05:53 AM
Die Nicky, Die. ryan General Discussions 43 04-22-2007 02:51 AM
HTML code is On
