losing pressure in brakes...master cylinder?? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 4 (permalink) Old 03-23-2010, 07:14 PM Thread Starter
im losing pressure in my front brakes. i bleed them, then a few days later, the pressure is low, if not gone again. i havent really noticed and oil leaks anywhere, so unless they are VERY small..i dont know what else it can be besides the master cylinder? any other ideas? and if it is that, how hard is that to change out?
sshhbequiet is offline
post #2 of 4 (permalink) Old 03-23-2010, 07:16 PM
deez nutz
(RRRRRR)'s Avatar
Bike: 08 R6
Re: losing pressure in brakes...master cylinder??
if no leaks, you have air in the system..
(RRRRRR) is offline
post #3 of 4 (permalink) Old 03-23-2010, 07:21 PM Thread Starter
they worked fine for the year that i have had the bike. but just recently i have noticed it...
post #4 of 4 (permalink) Old 03-23-2010, 10:26 PM
crashing aint so bad
luke geis's Avatar
Bike: 2005 red r6
Images: 10
check to make sure that the lever adjuster screw isn't backing out. i had a similar issue before and went through everything I could think of. One day it hit me that I had to adjust the lever adjuster screw in like three times. I thought to myself that there is no way it could keep going in like that. Then the light went on. Adjust the lever as you would and be sure of where it is adjusted. When the brakes seem to fade check the lever adjuster again to see if it has moved. if that is not the case the let us know.
luke geis is offline
How to Bleed (flush) Front Brakes on 06-07R6?? RadicalR6 How To's... 25 06-02-2010 03:54 PM
WTB: Front Radial Master Cylinder CTGlass Bikes + Parts + Gear Wanted 1 12-10-2009 10:04 PM
Problem with brakes - master cylinder? Fubba General Discussions 8 07-27-2009 01:46 PM
bleed master cylinder on 04?? help!! redwood650 General Discussions 6 04-23-2007 04:59 PM
Master cylinder replacement questions on brakes ptirmal Garage / Mechanical Help 2 06-09-2005 10:20 AM
