Educated estimate on RPM difference 15t vs. 16t - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 13 (permalink) Old 04-02-2010, 06:18 PM Thread Starter
Flamingtire's Avatar
Bike: 2002 Yamaha YZF R6
I will shortly be swapping my chain on my 2002 R6. Everyone (like literally everyone) tells me to go down one on the front sprocket. However, I ride on the interstate quite often.
When I ask "everyone" what the RPM difference will be in 6th gear going like 75, all they can say is that you will hardly notice it. I would like a more educated estimate/approximation on this difference. I pretty mechanically inclined, therefore I'm sure I would notice the different engine tone and tach reading...
So, anyone have any thoughts? The current setup is 16 48 (stock).
Flamingtire is offline
post #2 of 13 (permalink) Old 04-02-2010, 07:03 PM
crashing aint so bad
luke geis's Avatar
Bike: 2005 red r6
Images: 10
Re: Educated estimate on RPM difference 15t vs. 16t
almost 1,000 rpm more for same speed in same gear.
luke geis is offline
post #3 of 13 (permalink) Old 04-02-2010, 07:04 PM
Bike: 03 R6
Images: 2
I wish I could remember for you but I can't.
I think it was 500 but not more than 1000 rpm difference.
what I do remember at the track my speed with the stock gearing is about 134 at the end of the straight and with the 15 on the front it went up to 146(indicated) or so.
and with my 14 on the front it went up to 157 or so. (if only it was true LOL)
blue03r6 is offline
post #4 of 13 (permalink) Old 04-04-2010, 09:06 AM Thread Starter
Well see I would think thats a noticeable difference. Thanks for the replies. Ill assume its greater than 500 less than 1000 at this point. I use my bike for long trips so much that it wouldn't be intelligent to drop one in the front. If it was just my toy for weekend riding I would do it in a heartbeat.
post #5 of 13 (permalink) Old 04-04-2010, 10:39 AM
STOP PROJECTING ON ME@!!@
Captscooter 954 R6's Avatar
Bike: 2002 954, 2006 R6
just go up 1 or 2 teeth in the rear. its enuff to make it alittle more fun. but not enuff to make u think your winding the shit out of it just going down the highway. it will make about a 300-500 difference. at least thats what i would do.
2006 RAVEN-Full Yosh TRC Carbon System. Graves Block-Off Plates, PC3 USB, Shogun No-Cut Frame Sliders, Speedo Healer, Greggs Customs Front Flush Mounts. Powdercoated Pass. Pegs and Rearsets. Zero Gravity Clear Dubble Bubble. CRG Shorty Roll-A-Click Levers in Black. Michelin Pilot Power 2CT Front and Rear. EBC HH front Pads. Galfer Black Brake Lines. Acumen Digital Gear Indicator. GYTR Filter. Tuned Stock Suspension. Integrated Rear Turn Signals into Pass. Pegs with L.E.D.s
Captscooter 954 R6 is offline
post #6 of 13 (permalink) Old 04-04-2010, 10:55 AM
I like ice cream!
r6jon's Avatar
Bike: 09 Husky 610 SM, 06 R6
It changes your overall gear ratio by 7%. A little less than 1,000 rpm and highway speed, very noticeable.
Gear Ratios - Motorcycle Front/Rear Sprocket Combinations
14 15 16 17 18 19
49 3.50 3.27 3.06 2.88 2.72 2.58
48 3.43 3.20 3.00 2.82 2.67 2.53
47 3.36 3.13 2.94 2.76 2.61 2.47
46 3.29 3.07 2.88 2.71 2.56 2.42
45 3.21 3.00 2.81 2.65 2.50 2.37
44 3.14 2.93 2.75 2.59 2.44 2.32
43 3.07 2.87 2.69 2.53 2.39 2.26
42 3.00 2.80 2.63 2.47 2.33 2.21
41 2.93 2.73 2.56 2.41 2.28 2.16
40 2.86 2.67 2.50 2.35 2.22 2.11
by webBikeWorld.com
Like scooter said you can go up one or two in the rear for a smaller difference.
06 R6
"The only time fun happens is when you're having it."
r6jon is offline
post #7 of 13 (permalink) Old 04-04-2010, 01:00 PM
w cole's Avatar
Bike: 2001 R6, 2009 R6 Raven
1/16 = 6.25% difference. So go ride on the freeway at your normal speed, then add 6.25% to that to get what your RPM will be with the new sprocket. I'm not sure where you guys are getting a 1000 RPM gain from unless you're cruising at 16,000 rpm. I'd say a 500 RPM gain is a pretty good estimation.
2009 R6 "Raven": Vortex rearsets, Pazzo levers, eBay F.E., Custom LED Integrated Tail light, Hotbodies flushmounts, Michelin 2ct's, Black rims, Motovation frame, front/rear axle, and spool sliders, GYTR tank pad,
w cole is offline
post #8 of 13 (permalink) Old 04-04-2010, 01:47 PM
luke geis's Avatar
Bike: 2005 red r6
Images: 10
It is less than 1,000 that is for sure. It is different for different bikes and in different gears.
in 6th it's about a 400 rpm difference. in first it's nearly 800. This is at 60 mph keep in mind. At full speed ahead the difference will be close to 800 in 6th gear. 1 tooth difference in the front makes the largest impact on gearing. The rear is for fine tuning. Basically it works out to about 10 mph difference for the front sprocket. If you go up one you will be 10 mph faster, down one 10 mph slower, at the same rpm in the same gear.
post #9 of 13 (permalink) Old 04-04-2010, 02:33 PM
i said 3-500.. so don't lump me in with a bunch of smart guys ok.
lol
post #10 of 13 (permalink) Old 04-04-2010, 04:05 PM
Bike: 03 R6
Images: 2
it actually reads faster than you are going on the display. but it gets more off the faster you go.
every time I hit the braking marker with stock gearing in my videos I'm at 134 +/- 1-2 mph
with the 15 on the front that jumps up 10-12mph. I might actually be going a little faster. but I doubt its all that much faster. but it doesn't really matter to me, I like how I get up to top end faster.
that's what it's all about. because with stock gearing I can't keep up with my buddies 04 that makes 109hp at the rear wheel. after about 110 he pulls about 5 bike lengths on me. but with the 15 I can stay with him a little bit more. but with the 14 I have no worries of him leaving me behind like he does when I use the 16/48.
blue03r6 is offline
Difference between 03 rotors and 06-09 rotors? r6xy Garage / Mechanical Help 2 12-10-2009 06:49 AM
Front Sprocket Change Removal/ Percentage of difference 2blue Garage / Mechanical Help 15 05-02-2009 12:03 AM
WOW what a difference!! seating position.... r6-flame General Discussions 6 04-22-2009 04:09 PM
Difference in integrated tail lights... dprofeta Appearance and Exterior Mods 5 03-10-2009 08:24 PM
difference between dampers?? evolution1094 Suspension settings 6 02-21-2006 09:51 PM
