Fuel Light Keeps Flashing - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 05-05-2010, 08:38 PM Thread Starter
D33PU
Bike: 2004 R6
I had the tank off to get it painted. It still had a little bit of gas in it so When I put it back together i rode the bike to the gas station. On the way it was a solid fuel light then started to flash. I thought once filled it will stop. Still hasn't gone away after fill up. Its an 04 yamaha r6.
Help thank you
Custom grey/black, Hotbodies Double Bubble, two brothers Slip on, Black Pazzo shorties gold adjusters, fender eliminator kit, flush front signals, Carbon Fiber L.e.d Rear signals, -1/+2 520 D.I.D. conversion
D33PU is offline
post #2 of 5 (permalink) Old 05-05-2010, 08:45 PM
Spend ALL the monies!
Jiggaman13's Avatar
Bike: 07 Blu Bomba, 77 LB 80 3D
Re: Fuel Light Keeps Flashing
something is wrong with the fuel sensor
check on your connections under the tank and the wires going to the cluster and make sure there arent any breaks in anything.
2007 R6
05 Header || Termignoni Slip On || Power Commander III || BMC Filter || Shogun Frame Sliders || CRG Roll-A-Clicks
Clear Alternatives Smoked Integrated Tail || Proton Flushmounts || Smoked Windscreen || 8000k HID || Michelin Pilot Power 2CT
Shoei X11 || A* Black Label || A* SMX 5
Jiggaman13 is offline
post #3 of 5 (permalink) Old 05-06-2010, 08:11 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Yeah, I think if you don't reconnect the fuel level sensor wire under the tank it does just what you say. I forgot to put mine on when I did my carbs and the light was flashing or on
ChiefSmokeDawg is offline
post #4 of 5 (permalink) Old 05-06-2010, 08:36 AM
fuel level connection isn't connected. problem solved.
not to be a dick, but if you had just lifted your tank back up im sure you would have found the problem faster than going online and typing out this thread...
natedogg624 is offline
post #5 of 5 (permalink) Old 05-07-2010, 06:51 PM Thread Starter
D33PU
Bike: 2004 R6
I was holding the tank my buddy was connecting everything and I just opened up the tank and a connector not connected. Now everything is working thanks guys.
D33PU is offline
HID questions ChrisV Appearance and Exterior Mods 12 05-17-2010 10:19 AM
Low Fuel Light ducdaevil General Discussions 20 10-02-2008 12:16 AM
Fuel Light won't shut off... foxriderxr1 Garage / Mechanical Help 2 06-10-2008 07:05 AM
WTB 06 R6 Fuel Tank, light damage ok. Team Serpent Bike Parts For Sale 1 03-04-2006 01:34 PM
Low Fuel Light R6riverside General Discussions 2 03-28-2005 05:31 PM
