Quick question - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 16 (permalink) Old 10-28-2012, 08:45 AM Thread Starter
Knowledge is Power
CRACKERhead's Avatar
Bike: '99 Yamaha R6
Quick question
So after syncing the carbs on my '99 (thanks to research done on this forum), im hearing a noise coming from the engine and it sounds pretty much like the valves/tappets.
I know in the manual it says that u should first set the timing and valve clearances before moving on to synchronizing but this has been done when I serviced and replaced the cct about 1000miles back.
Should I have I checked the valve clearances again before syncing? Can the syncing be the cause of the noise that I'm hearing now? If so how and why?
The carbs was heavy out of balance so dispite the noise, she is pulling and reving up way better with more power. Idling is also much more stable and revs are coming down nicely to idle. I still feel throttle response is a bit sluggish from idle tho
Any input will be appreciated
ADDICTED like HEROIN
Cape Town
South Africa
CRACKERhead is offline
post #2 of 16 (permalink) Old 10-30-2012, 12:43 AM Thread Starter
Knowledge is Power
Bike: '99 Yamaha R6
Re: Quick question
Anyone? Sorry if this is a dumb question but i'm a newbie to bikes
Cape Town
South Africa
post #3 of 16 (permalink) Old 10-30-2012, 09:47 AM
Ride Blue
2004R6Rider's Avatar
Re: Quick question
Valve tick is pretty distinct; however, most engines, to some degree, will run with a barely-audible ticking sound. If you recently adjusted the valve clearances, I wouldn't worry about it, unless what you are hearing is OBVIOUS valve tick.
2004R6Rider is offline
post #4 of 16 (permalink) Old 10-30-2012, 11:03 PM Thread Starter
Knowledge is Power
Bike: '99 Yamaha R6
Re: Quick question
The sound is definitely coming from under the valve cover. (did the screwdriver to ear thing)
Whats puzzling is that its only evident after the carb sync. Engine was quiet after replacing the cam chain + tensioner and before syncing carbs.
If this is normal valve tick, could it then be that its only evident now because the engine is now running at its full potential since the carbs are now balanced?
Cape Town
South Africa
post #5 of 16 (permalink) Old 11-03-2012, 07:07 AM Thread Starter
Knowledge is Power
Bike: '99 Yamaha R6
Re: Quick question
Guys I'm paranoid here.
I took off the bottom cowlings just to get closer to the engine. I'm even more paranoid now coz the knocking sound is coming from the lower end as well.
How do I go about diagnosing this, coz I'm hearing the same sound under the valve cover and in the lower end. So is the sound travelling down from the valves or up from the rods...
When I give throttle the sound doesn't get louder but gets faster with the revs. Its there throughout the entire rev range from idle. When I drive its still there and I can even feel a vibration. Also, the knocking is not really that loud. U hav2 put ur ear real close to the engine to actually hear it. What bothers me is the vibration that its causing
How would I go about uploading a sound clip or video clip, would it be the same as uploading a pic?
Cape Town
South Africa
post #6 of 16 (permalink) Old 11-03-2012, 07:14 AM
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
What year bike and how many miles?
Go fast parts:
, Shorai battery.
Body:
Support the forum Vendors
bryan j is offline
post #7 of 16 (permalink) Old 11-03-2012, 08:03 AM
Big ol pile of them bones
Shush319's Avatar
Bike: listed in sig
Re: Quick question
99 duh.......
OP, how did you "adjust" the valves, "sync" the carbs? Did you get a new OEM CCT, or an aftermarket manual CCT? If you pull in the clutch does the sound seem less or go away?
CCS FL #379
Bikez:
01' Champions Limited R6 (retiring from racing) now traded for a truck :-( gonna miss the old girl))
88' GSXR 750 (recently restored)
02' R1 (sold)
07' R6r (Race/Street)
04' Zuma BEAST MODE ENGAGED! 70cc S6 BBK and pipe, 68mph on flat land!
01' XR70R (sold)
??' 50cc air cooled pocket bike (dangerous!)
90's Blata 40cc water cooled pocket bike (seriously dangerous! 50mph with my 170lb azz.)
99' CR125R (sold)
Shush319 is offline
post #8 of 16 (permalink) Old 11-03-2012, 08:14 AM Thread Starter
Knowledge is Power
Bike: '99 Yamaha R6
Re: Quick question
Its a 99 with 37000 miles
Cam chain and tensioner both came from yamaha. There was a hard start problem when warmed up so checked the valve clearances. I did not do this myself so I don't know how far out the clearanses was or which required adjusting.
The noise is there in nuetral with clutch in and out, and while driving with clutch in and out
Cape Town
South Africa
post #9 of 16 (permalink) Old 11-03-2012, 08:41 AM Thread Starter
Knowledge is Power
Bike: '99 Yamaha R6
Re: Quick question
Sorry, misread the question. Its an oem cct not a manual one. I synced the carbs myself using a homemade manometer, 2 bottles method. Syncd 1 and 2, then 3 and 4, then 2 and 3
Cape Town
South Africa
post #10 of 16 (permalink) Old 11-03-2012, 08:55 AM
Shush319's Avatar
Bike: listed in sig
Re: Quick question
Cam chain and tensioner both came from yamaha. There was a hard start problem when warmed up so checked the valve clearances. I did not do this myself so I don't know how far out the clearanses was or which required adjusting. Does it start easy after this?
They all make some "ticking noise". Some more than others.
Sorry, misread the question. Its an oem cct not a manual one. (OE CCT SUKZ Ballz!)I synced the carbs myself using a homemade manometer, 2 bottles method. Syncd 1 and 2, then 3 and 4, then 2 and 3
Really hard to get it right like this...... When you make the adjustment between 2-3, 1 and 4 will move some too. Its best to use the proper tool for the job. You can get a Motion Pro 4 way gauge off eBay (click link below) fairly cheap an well worth the $$ IMHO:
CCS FL #379
Bikez:
02' R1 (sold)
01' XR70R (sold)
99' CR125R (sold)
Shush319 is offline
Quick question need quick answer NJALLDAY Appearance and Exterior Mods 1 08-11-2010 09:28 AM
Quick quick question! Sartasz Appearance and Exterior Mods 1 04-21-2010 10:38 PM
Quick question Sapphyre General Discussions 18 06-16-2009 03:04 PM
quick question need help... jiggarex101 General Discussions 7 01-16-2009 07:13 AM
quick question.... teh jatt General Discussions 2 05-12-2006 10:17 AM
