Help please - R6 - White/creamy substance in engine... - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 18 (permalink) Old 11-10-2012, 08:18 PM
Re: Help please - R6 - White/creamy substance in engine...
Never seen oil turn milky white from a HG. Chocolate Milk, yes, Whole Milk or 2%? No. Plus he said isn't on the dipstick.
Also, if you had that much water mixed in with your oil, you would notice that your oil level is high and your coolant level would probably be low. Check the overflow reservoir to see coolant level.
theidealone is offline
post #12 of 18 (permalink) Old 11-11-2012, 07:47 AM
Just lean harder...
Phrozen's Avatar
Bike: 07 R6s
If the bike has been sitting for awhile its probly condensation mixed with oxidation of the aluminum. Start the bike up and let it idle till the fans cycle on then off twice, then shut the motor off. Now that the motor is good and warm take the oil cap off and let it sit, any moisture will be baked out from the heat. Or you could just go ride the piss out of it.
Modifications- PCV w/ Autotune, LCD, & Quick Shifter, GraveSport Slip-on, Slide Stops, K&N filter, Factory Pro +4 Ignition rotor, SuperFlare Velocity Stacks, AGG block off plates, Fren Tubo Type 4's, EBC HH Brake pads, 520 Driven Sprockets & EK ZZZ Chain, Penske 8987 shock, 07 USD Forks and Brakes in 05 Triples, ASV C5 Levers, Scotts Steering Damper, GYTR Carbon Chain Guard, GYTR Carbon Toe Guard, Canadian GYTR Frame Sliders, GYTR Carbon Tank Pad, BST Carbon Rear Fender, Competition Werks Fender Eliminator, UFO Integrated Tail Light, Metzler M5 D-Spec Tyres, Gilles Chain Adjusters & Lifters, Gilles Rear-sets, Powder Coated Passenger Rear-sets, GYTR Seat Cowl, SaddleMen Seat, Irate Customs Grill, Gregg's Flush Mount Signals, DDM 5K H.I.D.'s, Integrated Beltronics 985, and
Phrozen is offline
post #13 of 18 (permalink) Old 11-11-2012, 08:04 AM
ECK Racing
csmutty's Avatar
Bike: 06 R6, 08 FZ6, 05 KTM125
When checking her oil I usually see a milky white substance when I pull out the dipstick.
Try sticking it in one of her other holes and see if you get a different reading.
LRRS/CCS #316
| Pine Motorparts/PBE Specialists |
2011 Pit Bike Race CHAMPION!
csmutty is offline
post #14 of 18 (permalink) Old 11-11-2012, 08:10 AM
Official Noob Greeter
redisdeadrideblue's Avatar
Bike: stupid ones and a Prius
It is likely just condensation in the engine that vaporizes with the heat, then mixes with a small amount of the oil and adheres to the oil cap where it recondenses. Its probably not a big deal if the engine is still running and acting as it should. Keep checking the oil at the dipstick or sightglass for a while and if the condition persists of gets worse, you likely have a blown headgasket, at which point it will begin to consume coolant. If that is the case, it would belong before the thing wont run right, and then not start. Just keep checking your levels of coolant and condition of the oil and you should be fine. If it does get worse though, deal with it, dont ride it till it blows.
redisdeadrideblue is offline
post #15 of 18 (permalink) Old 11-11-2012, 10:24 AM
A work in progress...
TheJokester3's Avatar
Bike: 07 Candy Red R6
RIP Matt (Ghost R6). You will be greatly missed. Be smooth and the rubber turning till we meet again.
"I refuse to tip toe through life to arrive safely at deaths door".
Originally Posted by thedub View Post
There is more to squidliness than just your gear.
TheJokester3 is offline
post #16 of 18 (permalink) Old 11-11-2012, 10:42 AM
I wish I was titanium....
Iron55's Avatar
Bike: 2010 Pearl White R6
Iron55 is offline
post #17 of 18 (permalink) Old 11-11-2012, 11:49 AM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
That's what she said.
pickpocket293 is offline
post #18 of 18 (permalink) Old 11-11-2012, 12:42 PM
Dinkfore's Avatar
Bike: 99 R6 "project"
I promise I'll take it out first.
Dinkfore is offline
Substance use, legal or illegal ~03~Raven Off Topic Talk 41 08-10-2009 05:44 PM
A "stuck substance" LOL yoda Off Topic Talk 24 03-18-2008 10:22 PM
Substance BlueBartender General Discussions 11 07-19-2007 12:32 PM
black thick substance bsattak General Discussions 7 05-24-2007 04:45 PM
