Beam height? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 3 (permalink) Old 11-10-2012, 03:06 PM Thread Starter
I eat my r6
z0gR6rider's Avatar
Bike: 2007 Yamaha R6
Beam height?
I have used to awesome
Search button, and my google-fu is failing me at the moment. Maybe I am using the wrong keywords...
Question
What is the law for beam height for both high beams and low beams (HID)..
Distance + height.. If anyone can help, I would owe you one. I live in NC.
Thanks in advance!
Sent from my iPhone using Motorcycle
2007 Yamaha R6 Charcoal: -1/+2 Ratio, EK MVXZ Black chain. HID Angel eyes/devil eye. Scotts Damper. PUIG double bubble. PCV & Autotune, M4 Midpipe, ultra-high intensity LED Tail Light. (blaster-x) Arkapovic Carbon Slip, SpeedoDRD, EXUP plug.
z0gR6rider is offline
post #2 of 3 (permalink) Old 11-11-2012, 12:55 AM
Trading my way up
Bike: 2002 R6
Re: Beam height?
If you get 3 people bright you per mile then it's too high, under that your good
motorman251 is offline
post #3 of 3 (permalink) Old 11-11-2012, 01:39 AM
When in doubtThrottle out
mercenary's Avatar
Bike: Always Under Construction
Re: Beam height?
Google is unnecessary...but LMGTFY
In case you are incapable still:
20-131. Requirements as to headlamps and auxiliary driving lamps.
(a) The headlamps of motor vehicles shall be so constructed, arranged, and adjusted that, except as provided in subsection (c) of this section, they will at all times mentioned in G.S. 20-129, and under normal atmospheric conditions and on a level road, produce a driving light sufficient to render clearly discernible a person 200 feet ahead
(c) Whenever a motor vehicle is being operated upon a highway, or portion thereof, which is sufficiently lighted to reveal a person on the highway at a distance of 200 feet ahead of the vehicle, it shall be permissible to dim the headlamps or to tilt the beams downward or to substitute therefor the light from an auxiliary driving lamp or pair of such lamps, subject to the restrictions as to tilted beams and auxiliary driving lamps set forth in this section.
That answer it?
2009 YZF-R6
2010 Ninja 250
MCRA/CCS#81
Originally Posted by doctorv
I was wrong.
Quote taken 7-16-15 @ 0640CDT
mercenary is offline
High beam vs. Low beam BskooL General Discussions 22 02-11-2012 08:37 AM
How to set headlight beam height? latindane Garage / Mechanical Help 2 11-06-2009 08:31 AM
Making High Beam look like Low Beam iridetucked Appearance and Exterior Mods 6 09-21-2008 06:33 PM
high beam low beam question scooterroo Appearance and Exterior Mods 4 05-02-2008 06:29 PM
high beam/Low beam, what do you prefer Sh1tmeh General Discussions 14 09-08-2007 10:52 PM
