HELP! 06 R6 Dies on cold start and wont idle - Page 4 - Yamaha R6 Forum: YZF-R6 Forums
post #31 of 88 (permalink) Old 11-17-2012, 02:50 PM Thread Starter
Tracers work both ways
Pipelinz's Avatar
Bike: 04 R6 (Sold) 06 R6R
Re: HELP! 06 R6 Dies on cold start and wont idle
So I cleaned the TPS, it was a little dirty, but not too bad, buttoned everything up and flashed her up. Problem still exists, no change at all. I'm in the process of checking the valves right now. 2 beer into it so far and halfway through Metallica's Ride the lightening album.........lol. will post once valves are checked.
"If it's stupid but it works, it isn't stupid."
“Out of every one hundred men in battle, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back.” ― Heraclitus
Pipelinz is offline
post #32 of 88 (permalink) Old 11-18-2012, 09:20 PM
Suk it, Lee
Ryan5544's Avatar
Ryan5544 is offline
post #33 of 88 (permalink) Old 11-19-2012, 10:53 AM Thread Starter
Pipelinz's Avatar
Okay, so after a bunch of beers and some good tunes, I got the valves all checked. It was actually easier than I thought. Now the good/bad news.
Good news:Clearances were all within tolerance and everything looked good and I got to do it on my own, which was very satisfying.
Intake: 0.11mm ~ 0.20mm (0.0043in ~ 0.0079in)
Exhaust: 0.21mm ~ 0.30mm (0.0083in ~ 0.0118in)
Bad News:I now have no idea WTF is wrong with my bike. TPS was good, valves were good. I spoke with a Yamaha tech at my local shop and he seems to be thinking ECU and/or temp sensor. Anyone have anymore input? I guess I need to take it to the shop now and pay for some troubleshooting.
Pipelinz is offline
post #34 of 88 (permalink) Old 11-19-2012, 11:23 AM
Suk it, Lee
Ryan5544's Avatar
Well... Temp. sensor is cheap to replace....
I would think the ECU is quite a drastic conclusion to jump to, but who knows!
Ryan5544 is offline
post #35 of 88 (permalink) Old 11-19-2012, 11:28 AM Thread Starter
Pipelinz's Avatar
Yeah thats what I thought as well. I'll start with the temp sensor next I guess and go from there. At least the weather is miserable right now, so I am not missing much riding, still, I am starting to get a bit frustrated. In the end, at least I am getting to know my bike better. Will let you know what it is, when/if I ever figure it out.
Pipelinz is offline
post #36 of 88 (permalink) Old 11-19-2012, 11:30 AM
Suk it, Lee
Ryan5544's Avatar
What I wonder is though, if you take it to the guy to have it fixed, is he just going to replace the ecu, and charge you for it? (if it doesn't end up being the issue)
Or, is there a way they can test the current unit
Ryan5544 is offline
post #37 of 88 (permalink) Old 11-19-2012, 11:37 AM Thread Starter
Pipelinz's Avatar
Very good point, didn't think of that. I do have other shop options in town here, so I don't HAVE to take it there and after your comment, it might be good not to actually. I'll do a search to find if there is a way to test the ECU, vice just replacing it. Thanks for the info and idea, that's why I love this forum so much. I appreciate all your help and time on this PITA issue.
Pipelinz is offline
post #38 of 88 (permalink) Old 11-19-2012, 11:42 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Was anyone else not surprised the valves were within spec? OP indicated 29,000 KM not miles.
Good luck to you. Maybe someone has a spare ECU you can swap in to see if it helps. Any friend with an 06-07.
Is the air filter OEM also?
ChiefSmokeDawg is offline
post #39 of 88 (permalink) Old 11-19-2012, 12:03 PM Thread Starter
Pipelinz's Avatar
Yeah I was not surprised by the valves to be honest, but people had recommended to check them and since I was cleaning the TPS, thought I would get them checked anyway.
I will ask a buddy of mine on an 07 to see if we can try the ECU swtich, good idea for sure. The air filter was just changed in July. Thanks for the ideas.
Pipelinz is offline
post #40 of 88 (permalink) Old 11-19-2012, 03:33 PM
Over my dead body.
Bike: 09 Raven R1
I believe I had this same problem on my 2006 R6. This video shows my exact problem:
(1:55)
For him, his bike was stock and he fixed it by getting the valves adjusted.
For me, I changed the plugs and it seemed to help a tiny bit, and then I remapped the power commander from a custom european map the guy before me did to a full akrapovic map (I have a full termignoni system). This fixed the problem 100%, and it has never happened again in the past 2000 miles.
Hope this helps!
NSGF is offline
07 r6 rough idle then stalls on cold start t_kreutzberg Garage / Mechanical Help 53 05-25-2015 06:34 PM
low idle,misfiring, and dieing on a cold start darksithis1122 Garage / Mechanical Help 0 07-12-2012 06:49 PM
07 r6 rough idle then stalls on cold start t_kreutzberg Exhaust and fuel delivery 3 05-20-2011 02:46 PM
07 R6 Dies Instantly On Cold Start KrazyTurbo Garage / Mechanical Help 17 12-19-2009 02:07 PM
Cold start engines dies Atlanta Braves Baby! Garage / Mechanical Help 13 08-01-2007 02:50 PM
