I need help asap please - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 8 (permalink) Old 11-16-2012, 04:13 PM Thread Starter
Okay to give you the run down i have taken off the carbs cleaned them changed the oil changed the spark plugs. now the reason for all of this i am having a problem with my 2001 R6 when it gets to like 170 degrees and i start to release the clutch it will die/lose power and like try to cut off. I need help this is my only ride I just got it and im also very young I need help please and thank you
Rayceman is offline
post #2 of 8 (permalink) Old 11-16-2012, 06:40 PM
I get my corn from a jar
jihad_joe's Avatar
Bike: R1
Re: I need help asap please
Clogged air filter element
Clogged fuel filter
Clogged fuel tank breather hose
Deteriorated or contaminated fuel
Fuel pump
Faulty fuel pump
Faulty fuel pump relay
Fuel cock
Clogged or damaged fuel hose
Carburetors
Clogged pilot jet
Clogged pilot air passage
Sucked-in air
Damaged float
Worn needle valve
 Incorrectly installed needle valve seat
 Incorrect fuel level
 Incorrectly installed pilot jet
Clogged starter jet
Faulty starter plunger
 Incorrectly adjusted starter cable
jihad_joe is offline
post #3 of 8 (permalink) Old 11-16-2012, 08:32 PM Thread Starter
okay thanks i did check some of that but on the fuel pump how does that work cause mine just cuts on then after lke 5 sec turns off is that bad?
Rayceman is offline
post #4 of 8 (permalink) Old 11-17-2012, 07:24 AM
jihad_joe's Avatar
Bike: R1
here is the section from the service manual that may help.
post #5 of 8 (permalink) Old 11-17-2012, 09:07 AM Thread Starter
Thanks. but see i did that to check the pump and it does suck the fuel but only for like 5 sec's after that it stops sucking it. that's what i need to find out about. but thanks for the help
Rayceman is offline
post #6 of 8 (permalink) Old 11-18-2012, 07:09 PM
Ride Blue
2004R6Rider's Avatar
So let me get this straight.. you did the maintenance work BECAUSE the bike is dying after it warms up?
If that's the case:
Did you completely disassemble the carbs and clean them? That would rule out a lot of things that could be wrong.
Also, are you shutting off the choke after the bike warms up? I know this seems obvious but I just wanna rule it out!
2004R6Rider is offline
post #7 of 8 (permalink) Old 11-19-2012, 01:18 PM Thread Starter
Okay i understand and yes i take the choke off. but what happens when it gets to like 180 and you come to a complet stop and pull in the clutch it revs fine but when you go to take off it bogs/wants to die cause if you let the throttle go it will die. ima take it to the shop cause i have cleaned the carbs and they were all good i just cant seem to find whats wrong. ill let you know what the problem is but do let me know if you have any ideas
Rayceman is offline
post #8 of 8 (permalink) Old 11-19-2012, 01:23 PM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
The fuel pump runs till the carbs are full then stops and continues as needed. It's a LOW pressure system with Carbs.
Probably the pilot jets being clogged, or a stuck float needle not letting fuel into the bowl. Otherwise it prolly has gotten cold out, and leaned the bike so much you can't take off. So I'd also bet you have a slip on and the pilot adjustors aren't drilled out at all to adjust richer, etc.
On take off, your on the pilot jet circuit on the carbs. That's where your problem will more than likely be. Otherwise, maybe the TPS is all forked up, but it shouldn't advance the ignition that much to where it stalls out...
ChiefSmokeDawg is offline
need help.....asap.....please DSTAR General Discussions 2 11-19-2010 10:27 PM
Hid Help Asap lil_shane84 Appearance and Exterior Mods 0 03-12-2010 10:01 AM
Need Help ASAP!!! 1quick4 General Discussions 17 03-20-2007 09:50 PM
Need Help Asap!! loserdude861 General Discussions 5 03-01-2007 08:21 PM
