Quick turn throttles?? - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 18 (permalink) Old 11-22-2012, 11:33 AM
Track=Cocaine
R-Silaxin's Avatar
Bike: 06 R-6 Deathraven
Re: Quick turn throttles??
I'll be picking up that Motion Pro here REAL soon. With the ECU flash I found myself having to really work to get my throttle to WOT... I'd have to roll my hand up the throttle while accelerating... Motion Pro is definitely essential!
MY TRACK BUILD THREAD
MY TRACK DAY THREAD
MY YOUTUBE CHANNEL
MY FACEBOOK
R-Silaxin is offline
post #12 of 18 (permalink) Old 11-22-2012, 11:50 AM
ECK Racing
csmutty's Avatar
Bike: 06 R6, 08 FZ6, 05 KTM125
I have a euroturn throttle on my race r6 and love it.
LRRS/CCS #316
| Pine Motorparts/PBE Specialists |
2011 Pit Bike Race CHAMPION!
csmutty is offline
post #13 of 18 (permalink) Old 11-22-2012, 12:21 PM Thread Starter
Hello fellow nesrian. No issues with your ER? How long have u had it??How is the biggest cam on the kit compared to stock r6 throttle?
boloson is offline
post #14 of 18 (permalink) Old 11-22-2012, 12:30 PM
Tron has corrupted me
BigShepp's Avatar
Bike: 2005 R6 Raven "Deimos"
I'll explain. The MP kits are NOT 100% bike specific. They ask for your make and model to see if you will need the added stop/start switch and to see if your bars are the correct diameter. The bike specific part comes with your cable lengths. These are the bike specific parts.
What is NOT bike specific is the length of the entire kit. With my bike, 05 R6, the length of the required stop start switch and the kit itself is longer than my stock handlebar. Aftermarket heli bars are required, and those aren't bike specific either. Furthermore, the stop/start switch cable length is a good six inches shorter than the stock length on my bike. Additionally, the pin that drops into the handlebar is on a different location for the stock and MP switches.
Most, if not all of the fitment issues stem from the added Stop/start switch. If your bike doesn't require one, then chances are it will be a perfect fit. However if yours is a bike that requires the switch, you had better be prepared for quite a bit of modification.
When I finish my next project I'll be doing a write up on my install of the kit. All in all it's going to run me close to $400 because of all the extra parts I had to buy. I refuse to let the throttle hang over the end of the bar and I refuse to have heli bars that sit above the forks.
Hard work yields great rewards, but idle talk leads only to destruction.
Proverbs 14:23
“Faster, Faster, Until The Thrill Of Speed Overcomes The Fear Of Death.”
Hunter S. Thompson
"It wasn't until I went to college and I got my first motorcycle that I understood the thrill of speed."
Vin Diesel
BigShepp is offline
post #15 of 18 (permalink) Old 11-22-2012, 12:36 PM
ECK Racing
csmutty's Avatar
No idea how the largest cam relates to the stock throttle, as I have never had a stock throttle on the bike. The bike came with the euroturn already installed. Only thing I did was change cams. It came with the smallest cam installed and I put in the largest cam as the throttle was much too sensitive. With the largest cam in there it works well though. Gives me enough of a turn so that I can be precise, but also makes it comfortable to go wfo without hand adjustment. I'd offer you a chance to try it out, but with a blown motor that makes it kinda hard haha.
LRRS/CCS #316
csmutty is offline
post #16 of 18 (permalink) Old 11-22-2012, 12:45 PM
FastForward Performance
Tdub's Avatar
Bike: Honda Z50
In 2011 I had 2 brand new R6. Ordered 3 (one for spares) MP Revolver kits for the 2011 R6, received it and bolted it on.
Now I imagine if you go back a few years, you might run into some issues. But in my experience with the new bikes, that is not an issue.
Tdub is offline
post #17 of 18 (permalink) Old 11-22-2012, 01:37 PM Thread Starter
Ok so it's more of a space issue you're talking about. On my previous gixxer I did have to purchase the start/stop switch with the MP kit but never had an issue with space on the clipon. But I also had woodcraft clipons & they also make extra long bars as an option. U might want to look into that
Ouch. Sorry about your motor but at least u have all winter to fix or replace it. So no issues with the er so far eh? I've read in 2 or more instances where people had issues with the er kit. I cant say if it was install error or product error but with the price they're selling them for & those reviews, it kinda scared me from buying it. Might have to stick with motion pro but i really don't have the need for all the extra cams
boloson is offline
post #18 of 18 (permalink) Old 11-22-2012, 03:24 PM
BigShepp's Avatar
I would imagine with newer bikes you wouldn't need the switch, ad in that case I would expect it to work perfectly.
Yea I bought a pair of aftermarket clip ones, but the 05 R6 has a weird triple tree clip on setup. Any aftermarket set would stick up above the forks. I'm in the process of getting a set that will fit correctly
Sent from my iPhone using
Proverbs 14:23
Hunter S. Thompson
Vin Diesel
BigShepp is offline
the R1 quick turn throttle mod Agg2001 Garage / Mechanical Help 31 12-01-2014 05:54 PM
WTT: 08+ R6 Vortex gas cap kit for a quick turn gas cap kit Envycycles Bikes + Parts + Gear Wanted 1 05-10-2012 03:10 PM
Quick-turn throttle? danaatscootdotnet General Discussions 15 05-20-2008 12:06 PM
Do they make shorter throttles? and. kris242 General Discussions 2 09-02-2007 03:54 PM
Quick turn signal?? jbird Appearance and Exterior Mods 7 04-05-2005 10:47 AM
