Acumen vs healtech - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 30 (permalink) Old 11-25-2012, 09:41 AM Thread Starter
R6_Dude's Avatar
Acumen vs healtech
In my search for a gear indicator it seems that these are the two to be had. But which one? They are both plug and play (correct me if I'm wrong). I think the acumen has a little lag, not sure about the healtech.
So which one is best and easiest to install?
Also where's the best place to get one?
06 R6
R6_Dude is offline
post #2 of 30 (permalink) Old 11-25-2012, 09:51 AM
AFM #723
Doc-Ram's Avatar
Bike: 08R6, 16R3, 15R3, 07 150R
Re: Acumen vs healtech
I only have experience with Accumen, and it was a breeze to install. If you can get the tank lifted, the install is halfway done
The lag you talk about is only when down shifting. It will not know what gear it is in till the clutch is released. If you blip the throttle and dump the clutch, then, it'll know immediately. If you release the clutch slow, then it'll get confused.
Doc-Ram is offline
post #3 of 30 (permalink) Old 11-25-2012, 10:16 AM
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
i also went with accumen. for now.
Agg2001 is offline
post #4 of 30 (permalink) Old 11-25-2012, 10:31 AM
track fiend
easbaysav's Avatar
Bike: 14 D675R, 15 ST3RX, 15 R1
HealTech here, install and programming was a breeze. Install: lift tank, plug GI harness into OEM harness and tap two wires, done. Program: get bike on stands and go through the gears as per instructions. I've only ridden it around the block cause I had no fairings or slip-on on due to waiting parts for my track build, but everything worked as advertised.
easbaysav is offline
post #5 of 30 (permalink) Old 11-25-2012, 10:32 AM
What if you hold the clutch while dropping three gears and then dump the clutch?
Nathan - #425 - 07 Yamaha R6
35 Motorsports, Vortex Racing, Pit Posse Motorsports, Spy Optics, Suomy Helmets, 614 Paintworx, Optimal Racing, GP Tech
Nationwide Children's Hospital/Ohio Motorcyclists for Children
The Retrofit Source
natedogg624 is offline
post #6 of 30 (permalink) Old 11-25-2012, 10:40 AM
AFM #723
Doc-Ram's Avatar
I've dropped 2 gears, blipped and dumped clutch, recovers the correct gear in less than couple seconds, but expect a small delay.
Doc-Ram is offline
post #7 of 30 (permalink) Old 11-25-2012, 11:20 AM Thread Starter
R6_Dude's Avatar
Doc-Ram - Thanks. Saw your older post on the Acumen.
AGG: I thought you bought a Healtech from a member?
Does the acumen also require tapping into wires? I suck with anything electrical haha.
06 R6
R6_Dude is offline
post #8 of 30 (permalink) Old 11-25-2012, 11:32 AM
AFM #723
Doc-Ram's Avatar
The wiring loom comes specific for llamaja's. No need for tapping or splicing. I've had mine since my last 08, just transferred to current one when i sold previous one.
Only issue I had was the top sticky plate on it. Accumen sent 4 replacements, now thats good service
Doc-Ram is offline
post #9 of 30 (permalink) Old 11-25-2012, 12:38 PM Thread Starter
R6_Dude's Avatar
Acumen it is. Now where's the best place to buy?
06 R6
R6_Dude is offline
post #10 of 30 (permalink) Old 11-25-2012, 12:43 PM
Agg2001's Avatar
Isn't he gipro an acumen? Haha. Hell, idk. Whatever the GIpro is
(excuse typos, as this was a mobile posting)
Agg2001 is offline
Speedodrd vs healtech speedo healer pearldrumguy1229 Garage / Mechanical Help 7 10-22-2012 05:07 PM
HealTech GiPro X-Type Gear Position Indicator jettech01 Bike Parts For Sale 6 10-17-2012 10:43 AM
HealTech GiPro gear indicator not working with SpeedoDRD TheShadow General Discussions 2 08-04-2012 09:47 AM
Acumen DG8 - Which one? turtlesplatter Appearance and Exterior Mods 0 06-10-2011 10:21 AM
help with setting speedo healer from healtech r6forlife Garage / Mechanical Help 3 05-10-2011 11:20 PM
