Running lean with poor gas mileage - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 13 (permalink) Old 11-29-2012, 05:47 PM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Originally Posted by rye View Post
So after reading all the way through that massive thread I linked above I'm sure that this is what the shop did, but also really damn confused. Even thought the feature is a decade old, no one really seems to know for sure exactly what adjusting these numbers does and how best to do it. The worst part is that apparently most every bike will have its own default settings and since the shop didn't tell me what they were I guess I won't ever know (unless there's a way to "reset" the ecu or something?). If anyone here has an '04 and has messed with this I would be interested to know what your default C values are.
The shop set all of the numbers to 10 so I'm going to try setting them all to 5 and see how that affects the mileage. If that doesn't do it I guess I'll keep reducing them until I find something that works, but from what I understand after reading all that, just reducing all the numbers arbitrarily won't necessarily give me the best gas mileage.
Luke, I saw your big post in that thread and it looks like you know as much about this as just about anyone so if you have any specific advice it'd be appreciated! Were able to figure out what kind of affect different adjustments had on gas mileage?
That's exactly what I was referring to. Set it to oem settings bro.
Sent from my iPhone using
ChiefSmokeDawg is offline
post #12 of 13 (permalink) Old 11-30-2012, 01:17 PM Thread Starter
rye
rye's Avatar
Bike: '04 R6
Re: Running lean with poor gas mileage
Originally Posted by luke geis View Post
That's just it. It doesn't seem to do anything beyond idle. The bike will change the way it runs but not to a large degree.
yeah that's what it seemed like to me. Though the shop said setting all the numbers to 10 richened it a bit I didn't really notice much of a change in performance/response, if any, yet it apparently took away 20+ mpg.
That's what I planned but apparently different bikes, even ones of the same year and sold in the same country, may have different stock settings so since the shop never told me what they were I'll probably never know for sure. I'm going to call them but I doubt they'll know. My plan is to go from 10 across the board to 5 and then 0 if need be. It's gonna be raining here for a few days it looks like but once I'm able to test it out ill post the results
rye is offline
post #13 of 13 (permalink) Old 11-30-2012, 03:00 PM Thread Starter
rye
rye's Avatar
Bike: '04 R6
A thought just occurred to me. I didn't know about smog block off plates but I recently started looking into them (probably get some when I get a PC). As I understand they eliminate the emissions control stuff that pumps air into the exhaust to burn unspent fuel in order to meet standards, so if you're tuning the bike this can cause a misreading in the a/f ratio.
You guys think its possible that the shop was still getting a lean reading after adjusting the ecu even though I'm getting terrible mpg because of this?
Also, is the PCIII my only option for the 2004 r6?
rye is offline
Poor mileage '05 R6 ScubaSteve08 General Discussions 10 04-08-2012 09:27 PM
05 r6 Poor fuel mileage davey9237 Exhaust and fuel delivery 3 09-16-2009 11:32 AM
running lean??? bratsR6 Garage / Mechanical Help 7 05-07-2008 08:06 AM
03 running lean on low end registeredtopost Garage / Mechanical Help 6 05-18-2007 11:51 PM
Poor Mileage on '01 Mustard Exhaust and fuel delivery 3 07-04-2006 01:39 PM
