I still love her....but a cold start on these bikes are pathetic : / - Page 13 - Yamaha R6 Forum: YZF-R6 Forums
post #121 of 188 (permalink) Old 12-01-2012, 09:33 AM
Lifetime Premium
LiveFastDieLast's Avatar
Bike: 09 R6
Re: I still love her....but a cold start on these bikes are pathetic : /
Originally Posted by pickpocket293 View Post
You guys suck at parsing links for quotes.
I can't even respond to this as I am not sure what parsing is referencing here.
Keep your Knees in the Breeze
"Only two types of Whiskey I don't like, Dick and Throttle" - A Wise Man.
LiveFastDieLast is offline
post #122 of 188 (permalink) Old 12-01-2012, 09:35 AM
R stands for RaceBike
bruiser's Avatar
Bike: 2009 R6
^^this
Speed doesn't Kill, The abrupt deceleration does.
Originally Posted by JT Money
When you wreak get inside of me
Ingredient List
Armour Bodies Track Fairings
Flash Tune ECU
K&N Air Filter
RaceTech Gold Valves
RaceTech Springs
Vortex Gas Cap
Driven-1,0 Gearing
05 header
GYTR Slip-On
Galfer Rear Wave Rotor
Green Type 3 Fren Tubo lines
bruiser is offline
post #123 of 188 (permalink) Old 12-01-2012, 09:38 AM
bruiser's Avatar
Bike: 2009 R6
Originally Posted by Blade-Brown View Post
Woah really the plugs are recommended to be replaced at only 8k?! I know everyone's plugs will wear differently based on riding, but for those of you who changed em out at 8K did you notice any of them fouled? Explain the purpose of block off plates. Thanks
yes 8k, mine were getting pretty bad when i changed them at 8k, wasn't running bad yet but i do all scheduled maintenance as scheduled, block of plates remove the AIS system(that pumps air back in to the motor, Like an EGR system on a car) removing this make's SOOO much room to change the plugs out for next time. Since you ride daily 8k miles will come up quick. do you need it? probly not, Is it convenient? yes and when you do mod it it makes it easier to tune
Ingredient List
Flash Tune ECU
K&N Air Filter
RaceTech Springs
Vortex Gas Cap
Driven-1,0 Gearing
05 header
GYTR Slip-On
bruiser is offline
post #124 of 188 (permalink) Old 12-03-2012, 09:35 AM Thread Starter
Bike: 09 R6 - 08 RR (SOLD)
Thanks man. I'm at 7,200 miles as of current. How hard/invasive is the spark plug change? Do I need to lift/pull the tank etc? Do you recommend staying with the OEM plugs as a replacement? How involved is the removal of the AIS system? I assume this system was put in place for pollution/emission control and most likely just hinders performance eh?
To everyone else, I will definitely have cyclegear load test and top off/replace my battery and I'll post up what I find!
Ok, back to the chit-talking, this thread is kinda getting boring
2009 R6 Black/Charcoal
BAUCE Tune - BMC Track filter
2008 CBR 600RR Graffiti (SOLD)
2001 F4i (I miss you, please write)
Blade-Brown is offline
post #125 of 188 (permalink) Old 12-03-2012, 09:52 AM
Sometimes..........
bluerebel's Avatar
Bike: 2012 R6
To answer all the question you asked above..... Use the search button.
All those topics have a write up w/ pics.
It's not terribly difficult... Just buy some beer, turn on pandora and your set.
Sent from my iPhone using
bluerebel is offline
post #126 of 188 (permalink) Old 12-03-2012, 11:30 AM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
Parsing links correctly involves quoting someone correctly such that the
Originally Posted by dumbass
quote
looks like it should, and the correct person is quoted. Don't delete the "/quote" part or the "quote=dumbass" part and you're 90% of the way there.
pickpocket293 is offline
post #127 of 188 (permalink) Old 12-03-2012, 11:54 AM
Lifetime Premium
Bike: 09 R6
Parsing links correctly involves quoting someone correctly such that the looks like it should, and the correct person is quoted. Don't delete the "/quote" part or the "quote=dumbass" part and you're 90% of the way there.
I see what I did. I Quoted a bad Quote Job...
post #128 of 188 (permalink) Old 12-03-2012, 12:51 PM
Giggity
robthezombie's Avatar
Bike: 07 r6 raven
My bike takes about 2 seconds and its been as low as 40 here lately on a few occasions. But it does sound awful and weak while it warms up.
Sent from my SAMSUNG-SGH-I997 using Motorcycle.com Free App
robthezombie is offline
post #129 of 188 (permalink) Old 12-03-2012, 01:08 PM
But I ride a Yamaha!
honda4life05's Avatar
Bike: 11' Red Raven
[/QUOTE]
That is how everything in my garage gets done
If you ain't first, you're last.
honda4life05 is offline
post #130 of 188 (permalink) Old 12-11-2012, 08:51 AM Thread Starter
Originally Posted by kingnba6 View Post
yamahas and cold do not mix. have the same type of problem with me r1. but i still love my yamaha
This dude above is right...the colder it gets, the more my 09 starts and sounds like a huge turd
It dipped into the 40's last night here in Arizona (from the 80's last week ugh) which may the coldest it has gotten this year, and upon cold start today, she took about 5 seconds to turn over and then just sounded/looked pathetic. The bike fires right up after it's been initially started for the first time. She just doesn't like getting out of bed I guess
In addition to that, for the first time ever, I noticed a "sticky throttle" in which I'm assuming was attributed to the cold. I know since 06, Yamaha has been using the cable-less "fly by wire" throttle (YCC-T = Yamaha Chip Controlled Throttle) so there is no direct physical connection between the throttle at your hand and the throttle bodies. What I experienced was that upon letting off the throttle to clutch in and shift, the throttle/tube would either stick or even jump forward/up but not snap/roll back as it should. This happened for the first 15 minutes of the ride (letting off the throttle between shifts would rev/shoot up the rpms) and then eventually it started rolling back/functioning properly as it should. It was just a little scary to see that this chit happens...I don't feel like doing a wheelie into a curb when I'm merely trying to shift all because the throttle tube is sticky from the cold (WTF?)
06 R6 cold start rufio0205 Garage / Mechanical Help 14 05-10-2014 08:45 PM
Too Cold To Start? C-BUS R6 General Discussions 16 01-14-2011 01:56 PM
how many bikes have u had will u always love the r6? jonblaze General Discussions 39 07-24-2010 01:52 AM
Cold Start Stalling jjm004 General Discussions 13 07-06-2006 10:34 AM
COLD START???? SpeedSen General Discussions 14 02-06-2005 02:43 PM
