1/4 mile height and suspension setup - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 10 (permalink) Old 12-03-2012, 08:40 AM Thread Starter
yamaguy
rivasjr725's Avatar
Bike: 13 r6
im looking to go to the 1/4 mile in the spring and im wondering if anyone has any advice on setup for the 1/4
currently im lowered an inch in the front ans stock height in rear, i do have a 1-2in lowering links for rear, would lowering the rear an inch or 2 help with 1/4 times and launch?? or leave stock rear and 1 inch in the front?
my suspension setup i have 3 lines stiffer (than stock) in preload in the front to reduce nose diving under hard braking and 2 clicks stiffer (than stock) on rebound.
on the rear i have the preload turned all the way up to reduce squat on the rear (which i hate) and also helps too power wheelie. i also ride a passanger alot so helps keep the tail up
but im sure this will hurt some on launch as it will be TOO stiff and front will come up easier
my bike wheelies very easy on the stret and under full throttle the front comes up ahout 3 inches in 1st
i have olson slip on, power commander with dyno tune and -1+2 on sprockets
rivasjr725 is offline
post #2 of 10 (permalink) Old 12-03-2012, 08:46 AM
Yeah Science!
wutsup's Avatar
Bike: gixxer chrome edition
Re: 1/4 mile height and suspension setup
I'm sure redisdeadrideblue will help you out. I think he still has his 636 drag bike so he should know a bit about setting up a bike for drag racing.
Chris
06 GSXR 750
08 Track R6 RIP
wutsup is offline
post #3 of 10 (permalink) Old 12-03-2012, 08:49 AM
Official Noob Greeter
redisdeadrideblue's Avatar
Bike: stupid ones and a Prius
I would do -3 in the rear, pull the forks up a little bit, maybe an inch, and put a lowering strap on the front. That should be plenty to get you solidly into the 10s.
redisdeadrideblue is offline
post #4 of 10 (permalink) Old 12-03-2012, 09:53 AM Thread Starter
yamaguy
rivasjr725's Avatar
Bike: 13 r6
could you explain please? raise the front to stock height and then strap it down?
how do you strap it down?
post #5 of 10 (permalink) Old 12-03-2012, 10:11 AM
I would pull the forks up through the clamps about an inch total. Then, buy a strap and bracket kit. The brackets mount to the brake calipers and provide a mounting point for the lowering strap. The lowering strap is basically a tiedown strap with different ends. It loops from caliper, over the frame behind the steering head, then down to the other caliper. When you pull the loop tight, it compresses the fork down, lowering the front more.
Schnitz Racing sells the kit.
post #6 of 10 (permalink) Old 12-03-2012, 10:30 AM Thread Starter
yamaguy
rivasjr725's Avatar
Bike: 13 r6
how is that ,much more different than just having the front lowered through the clamps like i have now? because the forks arnt compressed right now and with the straps they are?
flasthune ecu, dynojet quickshifter, black driven steel sprockets (-1+2) with gold EK chain, mjs race headers. set of Q3's, spiegler steel braided brake lines,
post #7 of 10 (permalink) Old 12-03-2012, 12:57 PM
Weeeeeeeeeeeee
Xtina's Avatar
Bike: '13 Ninja 300, '07 Gix600
Yep
2009 FZ6R - grocery getter
2004 CBR600RR- track
2013 Ninja 300- sold
2009 R6 -sold
SOAR #818
Xtina is offline
post #8 of 10 (permalink) Old 12-03-2012, 01:01 PM
It allows you to lower the front more which DRAMATICALLY reduces the ability for the bike to wheelie. I say use the strap and pull the forks up because you can get an inch with the fork pull, then another 3 with the strap without bottoming out the fork completely which can be dangerous if you overload the front, especially on the brakes at the tall end of the track.
post #9 of 10 (permalink) Old 12-03-2012, 02:47 PM Thread Starter
yamaguy
rivasjr725's Avatar
Bike: 13 r6
anybody have suggestions on suspension setup? like my rear preload if its too stiff turned all the way up right now?
should i soften it up to have some squat or leave it?
post #10 of 10 (permalink) Old 12-03-2012, 03:12 PM
you want it to squat a little but not so much that it breaks traction. I keep low speed compression soft in the rear, and the high speed pretty stiff to absorb that initial hit. As for preload, I dont use much, but then, my rear travel is limited by the swingarm hitting the subframe. The front is kinda useless to mess with if you use a strap.
Suspension and ride height BIERAAP RACE Section 12 07-24-2012 06:59 AM
Help with R6 setup to achieve minimum height r6vn Suspension settings 9 05-13-2012 11:48 AM
need help | suspension / height rico750 Suspension settings 15 02-15-2010 09:20 PM
Suspension setup!! gripnrip General Discussions 25 07-12-2008 05:12 PM
Suspension setup in AZ spekteR6 South West 3 11-24-2006 02:43 PM
