Need help with my 2000 r6 - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 16 (permalink) Old 12-04-2012, 12:16 PM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: Need help with my 2000 r6
Originally Posted by rich16 View Post
So if i bend them down towards that needle i sould be set
If you don't bend em too much and starve the carb for fuel as a result... That type of mistake will buck you off that bike mid turn.
ChiefSmokeDawg is offline
post #12 of 16 (permalink) Old 12-04-2012, 03:40 PM
Is it Deals Gap time yet?
CBR240's Avatar
Bike: 2007 R6
The service manual will have the "float height", and tell you exactly how to adjust. The normal deal is to remove the carb, remove the float bowl. Turn carb upside down, and bend until you meet certain measurements that are in the manual (such as set float height = "bottom of carb body to top of float = 0.74 inch + or - 0.04" this is an example, I don't have the 2000 R6 manual).
When doing a hack job on a MX bike at the track (simple old MX bikes is what my experience is mainly limited to) you would:
- unscrew the cover (or bowl), if turning the gas on causes fuel to flow from the overflow tube (with bowl in place), then the float retainer needs to be bent to press on the needle valve (fuel shut off valve) without needing so much "float". If you can't get it to stop with reasonable bending, then something is wrong with the needle valve, or the float don't float
(actually another thing to check, they do crack sometimes).
- Once it's not dripping out the overflow, then you can turn the gas on while holding the bowl in place, and see how much you need to lower the bowl to get gas flowing again. If you have to lower it much, then the needle value is too "tight", and you will not get enough fuel height in the bowl. So, loosen (or bend the other way, so the float has to raise higher to cut off fuel) the needle valve retainer.
Also, you have 4 carbs on your R6, right? Is fuel coming out all 4 overflows? If so I'd have to wonder if the fuel pressure switch is not working. Sorry, I have FI R6, so I'm really not much help here
CBR240 is offline
post #13 of 16 (permalink) Old 12-04-2012, 05:09 PM Thread Starter
Bike: 2000 yamaha r6
Yes i have 4 an yea it comes out of all of them an thats what im thinking the fuel persure an im not sure where thats at
rich16 is offline
post #14 of 16 (permalink) Old 12-10-2012, 01:45 PM Thread Starter
Okay so i had time to do it an i moved the level down an put them back togather an then it didnt start at all so took it back apart an moved then up i tiny bit an now they dont flood but it the bike falls an dies out at 6k
rich16 is offline
post #15 of 16 (permalink) Old 12-10-2012, 05:09 PM
Big ol pile of them bones
Shush319's Avatar
Bike: listed in sig
It's more complicated then that. the have to be in the right spot or you'll be either too lean or too rich. A TINY adjustment will make a HUGE difference. not something you should be blindly doing at all. The float level has to be measured, adjusted to the proper height, then tuned from there.
Like I said before, it's a real pain in the azz to get right.
CCS FL #379
Bikez:
01' Champions Limited R6 (retiring from racing) now traded for a truck :-( gonna miss the old girl))
88' GSXR 750 (recently restored)
02' R1 (sold)
07' R6r (Race/Street)
04' Zuma BEAST MODE ENGAGED! 70cc S6 BBK and pipe, 68mph on flat land!
01' XR70R (sold)
??' 50cc air cooled pocket bike (dangerous!)
90's Blata 40cc water cooled pocket bike (seriously dangerous! 50mph with my 170lb azz.)
99' CR125R (sold)
Shush319 is offline
post #16 of 16 (permalink) Old 12-10-2012, 06:18 PM
CBR240's Avatar
Bike: 2007 R6
OP - I think you've proved float height is the issue.
OK, so I had to find a service manual for your bike.
You can download a service manual here:
Download both the 1999 Service Manual and the 2000 Supplement.
Look in the 1999 manual (there is only a 2000 supplementary manual that does not mention float height). I assume 1999 and 2000 had same carbs? IDK for sure.
They describe the correct way to set float height on your carb. Seems easy, but they suggest a special tool (Fuel level gauge 90890-01312). See 6-12 in the 1999 service manual. Doesn't look like it would cost much. Basically a bent tube to attach where the drain is now, with a level sight of some sort at the end.
You probably could just use clear fuel hose (rather than the Yamaha tool), they show you where it should be. I think they are saying that it should just be 17.5 - 18.5 mm below the mark on the carb body.
Maybe someone here that has done this can say for sure.
Float adjustment as described in the 1999 Yamaha R6 service manual:
MEASURING AND ADJUSTING THE FUEL
LEVEL
1. Measure: fuel level a
Out of specification  Adjust.
Fuel level (below the mark on
the body) 17.5  18.5 mm
a. Stand the motorcycle on a level surface.
b. Place the motorcycle on a suitable stand to ensure that the motorcycle is standing straight up.
c. Install the fuel level gauge 1 onto the fuel drain pipe 2 .
d. Loosen the fuel drain bolt 3 .
e. Hold the fuel level gauge vertically next to the line 4 on the float chamber.
f. Measure the fuel level a .
Fuel level readings should be equal on both sides of the carburetor assembly.
2. Adjust:
 fuel level
a. Remove the carburetor assembly.
b. Check the needle valve seat and needle
valve.
c. If either is worn, replace them as a set.
d. If both are fine, adjust the float level by slightly
bending the float tang 1 .
e. Install the carburetor assembly.
f. Measure the fuel level again.
g. Repeat steps (a) to (f) until the fuel level is
within specification.:
CBR240 is offline
2000 YZF R6 Race Prep - $2000 tsd345 Bikes For Sale 0 05-30-2012 05:43 PM
FS: 2000 - R6 - Black - $2000 - 7000 miles - Michigan somewhere spdrace11 Bikes For Sale 2 08-02-2011 03:03 PM
FS: 2000 - R6 - Champions Edition - $2000 OBO - 30,000 miles - Washington Illernoise Bikes For Sale 14 11-21-2010 09:03 PM
FS: 2000 - R6 - Blue - $2000 - 32,000 miles - Albany, Oregon yotaismygame Bikes For Sale 1 05-21-2010 07:31 PM
