leaning leaning leaning - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 16 (permalink) Old 12-06-2012, 11:10 AM
GET OVER IT
R6BLONDIE's Avatar
Bike: '08 R6
Go to the track and get instruction from the control riders as mentioned above. U will hurt yourself or kill yourself trying otherwise
If you are in the nj vicinity go to the track with absolute cycle or nesba
Sent from my ADR6300 using Motorcycle.com Free App
~ R6BLONDIE ~
That Yamaha...
R6BLONDIE is offline
post #12 of 16 (permalink) Old 12-06-2012, 11:11 AM
Ride Blue
2004R6Rider's Avatar
Re: leaning leaning leaning
It all comes down to two things: body positioning and throttle control.
As some posters have already said, your aim is to LESSEN the lean angle of the bike at any given speed. How do you do this? With body positioning. By bringing your center of gravity over and down into the turn, you can corner just as fast as a neutrally-positioned rider who is leaning his machine over significantly more than you are. Guess who runs out of tire first?
But before you can do things like that, you need to master the basics. Are you sure you are even positioned properly when upright and centered? Many riders put too much weight on the front or rear end or grip the bars too tightly. You need to develop a fluid, relaxed, centered body position before you are ready to do any sort of proper cornering.
The next step is throttle control. The throttle is your best friend. Until you can get along with the throttle, you're a sitting duck as far as mid-corner crashes go. Riding a sportbike is all about fluidity, finesse, and control, not balls-to-the-wall lean angles and wide-open throttle.
2004R6Rider is offline
post #13 of 16 (permalink) Old 12-06-2012, 11:20 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
When is it gonna be warm enough to take a ride? Let me know and I'll take you out up by me and we can work on your riding. I ain't gonna take you anywhere to get your knee down or anything in this weather and shitty conditions, but I'll get you on some sweepers so you can settle into a turn for a change and work on correct body position, etc.
I need a ride BADLY and I've got at least 6 gallons of race gas to burn. Lemme know.
ChiefSmokeDawg is offline
post #14 of 16 (permalink) Old 12-06-2012, 11:28 AM
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
OP - what is your goal? If you just want to get the bike leaned over a lot and look cool, just go through the same turn at a higher speed.
Lean angle is just a function of the radius of the turn, and the speed your going through it (center of gravity changes it a bit, but you don't have a huge amount of control over that).
Be warned, if that's your goal, you're probably going to crash sooner than later, and it's going to suck.
A better goal is to learn how to be a better rider and focus on throttle control, smooth braking, turn-in points, counter steering and body position. Gain confidence, be smooth, and your speed will pick-up, and then you'll be leaning the bike over more, comfortably, without giving it much thought.
Fallis is offline
post #15 of 16 (permalink) Old 12-06-2012, 11:42 AM
A work in progress...
TheJokester3's Avatar
Bike: 07 Candy Red R6
RIP Matt (Ghost R6). You will be greatly missed. Be smooth and the rubber turning till we meet again.
"I refuse to tip toe through life to arrive safely at deaths door".
Originally Posted by thedub View Post
There is more to squidliness than just your gear.
TheJokester3 is offline
post #16 of 16 (permalink) Old 12-06-2012, 03:18 PM
The R stands for Respect!
Monster's Avatar
Bike: 2012 YZF-R6
Originally Posted by mercenary View Post
Lean angle is not the goal, lack of lean angle at a given speed IS the goal.
The difference between "trying" to look cool and actually knowing what your doing!
Monster is offline
Dies when leaning right mrbrettbaker Garage / Mechanical Help 12 09-04-2011 11:52 AM
Bike leaning towards the right imaninja General Discussions 18 07-12-2008 07:30 PM
leaning after drop MARKo Track Tech & Riding Techniques 7 04-29-2008 07:55 PM
Leaning??? herman818 General Discussions 18 11-28-2007 11:21 AM
leaning the bike? bpowa General Discussions 29 12-09-2005 11:07 AM
