what did I get myself into? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 14 (permalink) Old 12-09-2012, 06:22 PM Thread Starter
well I don't think it's that bad but I could use some help.
Anyway, I installed a 2008 r6 into a 2005 yfz450 roller. after a day of messing with the wiring I got it to run. Note it didn't run very well. It started the first time, idled and then reved to the moon. next time it idles but when given throttle, it would die. I went into diag mode and made sure all the values were correct. The only codes that come up are 17 exup and 23 air pressure sensor but I'm working on those (I have the exup plug coming in the mail)
I continued to mess around with it and now it wont run.
Fuel pump works, has spark, turns over...
unfortunately I think I messed up some how. When I thought it wasn't getting enough fuel, I tried turning the key on and off a few times. This lead to the secondary injectors popping off the rail. How do I put those back together without them leaking?
for now I want to fix the leak before it goes up in flames
Additional info:
the bike is canadian
harness and ecu were purchased from an American bike to eliminate immobilizer
drewski604 is offline
post #2 of 14 (permalink) Old 12-09-2012, 06:25 PM
When in doubtThrottle out
mercenary's Avatar
Bike: Always Under Construction
Originally Posted by drewski604 View Post
Additional info:
the bike is Canadian
Found your problem
2009 YZF-R6
2010 Ninja 250
MCRA/CCS#81
Originally Posted by doctorv
I was wrong.
Quote taken 7-16-15 @ 0640CDT
mercenary is offline
post #3 of 14 (permalink) Old 12-09-2012, 06:25 PM
* * * Punisher * * *
daisbest's Avatar
Bike: 2005 raven R6
Re: what did I get myself into?
Additional info:
well that explains it
MODS:
* Roth industries smog block offs
* Zero gravity smoked DB
* Shermoto shorty levers
* Scotts steering damper
* 06 shorty muffler conv.
* 520 chain conv. -1/+2
* Factory pro +4 rotor
* BMC race filter
* Dunlop Q2's
* Dynojet Pc3
* 12k h.i.d kit
daisbest is offline
post #4 of 14 (permalink) Old 12-09-2012, 09:45 PM Thread Starter
guess real help is hard to find!
post #5 of 14 (permalink) Old 12-10-2012, 08:09 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
If you gave more details about what you mean by messing with it, that would help.
The EXUP code and the intake temp sensor codes are common. The intake sensor is on the front of the bike in the ran air tract. You are most likely missing that piece.
EXUP, you can flash ECU or get an exup eliminator plug for.
What air filter are you running? What exhaust, or what kind of exhaust have you rigged up?
ChiefSmokeDawg is offline
post #6 of 14 (permalink) Old 12-10-2012, 08:29 AM
Was the engine in working condition before the retrofit?
Nathan - #425 - 07 Yamaha R6
35 Motorsports, Vortex Racing, Pit Posse Motorsports, Spy Optics, Suomy Helmets, 614 Paintworx, Optimal Racing, GP Tech
Nationwide Children's Hospital/Ohio Motorcyclists for Children
The Retrofit Source
natedogg624 is offline
post #7 of 14 (permalink) Old 12-10-2012, 04:54 PM Thread Starter
yes the engine came from a running bike. As for more details the exhaust is a custom made header made from 1 1/2" mandrel pipe that goes into a can from a gsxr 600. It was fired up with open headers. As for the air filters, I tried fitting pods but realized they wont work due to the secondary injectors that sit inside. (I think thats why they came apart?) the wiring has been changed to a harness from an American 2009 model and the ecu is from a 2010.
When the bike was started, it idled high then reved out. The second time it idled but had no throttle response and died.
Could it be that I had the 2 tps plugs are in the wrong ones?
Thanks for any insight on this.
post #8 of 14 (permalink) Old 12-10-2012, 04:55 PM Thread Starter
forgot to mention that I have a PCV on the way
post #9 of 14 (permalink) Old 12-10-2012, 08:32 PM
My Power band is blue
NorthShoreR6S's Avatar
Bike: 2009 sold,2008 R6 pink
I need a new sig, Can someone make me one please?
NorthShoreR6S is offline
post #10 of 14 (permalink) Old 12-10-2012, 08:49 PM
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, V-Star
Originally Posted by NorthShoreR6S View Post
FIFY.....
8Ball is offline
