06 track plastics and stock exhaust - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 7 (permalink) Old 12-10-2012, 05:26 AM Thread Starter
bleed Yami
Dewey's Avatar
Bike: 06 R6(track), 10 Z1000
Quick question, I was told the track plastics will not fit properly with the stock exhaust (cat), they will sit about an 1" lower. In order to get the proper fit I will need a full exhaust, is this the case?
Dewey is offline
post #2 of 7 (permalink) Old 12-10-2012, 05:45 AM
roaming gnome
cmedrive's Avatar
Bike: 2008 R6
Re: 06 track plastics and stock exhaust
You don't need to buy a full exhaust, you can keep your headers. You just need to delete the cat. I'm getting a set of track plastics from Anthony at Bauce and I'm having a midpipe welded in to delete the cat. Then I'll pick up a slip on from Anthony as well to complete the exhaust.
I'm using a Ttuners -
But there's also MJS -
cmedrive is offline
post #3 of 7 (permalink) Old 12-10-2012, 06:01 AM
scared of big tracks
smalltrack's Avatar
Bike: 07 R6, 09 R1
I ended up getting the full system from MJS and sent back all my OEM stuff so it ended up coming out pretty cheap.
smalltrack is offline
post #4 of 7 (permalink) Old 12-10-2012, 06:02 AM
Bike: 07 R6
I run the stock exhaust with Sharkskinz lower. It is an older belly pan, so I'm not sure if that makes a difference.
The biggest problem is heat. I've heat shielded the fairing with aluminum panels. But I still have had things melt, like the kick stand switch and the drain tubes near the oil filter.
narve00 is offline
post #5 of 7 (permalink) Old 12-10-2012, 07:38 AM Thread Starter
bleed Yami
Dewey's Avatar
Is the mid pipe and headers two different pieces? You talk about welding. I have a Yoshi slip-on now, don't want to buy a full system if I can just delete the cat.
Dewey is offline
post #6 of 7 (permalink) Old 12-10-2012, 07:41 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
You cut it into two different pieces. You would be cutting out the muffler in the belly pan and replacing it with the t-tuners pipe.
No need for a full system if you don't want one.
ChiefSmokeDawg is offline
post #7 of 7 (permalink) Old 12-10-2012, 09:28 AM Thread Starter
bleed Yami
Dewey's Avatar
Thanks for the info guys....always nice to get the answers to save me a few bucks.
Dewey is offline
08 r6r Plastics, Cluster, and Stock Exhaust CrashDummy2183 Bike Parts For Sale 5 09-18-2010 08:23 PM
07 r6 stock exhaust/cat with track plastics chase Garage / Mechanical Help 14 03-24-2010 08:30 PM
WTB: 99-02 R6 plastics and stock exhaust bracket squirrel_girl Bikes + Parts + Gear Wanted 3 12-31-2009 03:29 PM
FS:07 R6 Termi exhaust, Stock and Race Plastics TomCat3113 Bike Parts For Sale 28 06-04-2009 06:17 PM
Quick change from stock plastics to track skins? Jason D Track Tech & Riding Techniques 15 04-29-2009 01:54 PM
