Blinker problem - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 12 (permalink) Old 12-18-2012, 04:03 PM Thread Starter
scibona55's Avatar
Bike: 2005 Raven
Arrow Blinker problem
All blinkers on my bike flash when I use my turn signals (both L & R). I've been told that it may mean there is a bad ground in the system... any ideas what the problem may be or how to fix it?
scibona55 is offline
post #2 of 12 (permalink) Old 12-18-2012, 04:22 PM Thread Starter
scibona55's Avatar
Bike: 2005 Raven
Re: Blinker problem
Watch the video ---->
post #3 of 12 (permalink) Old 12-18-2012, 05:10 PM
Re: Blinker problem
need to make sure the blinker fluid is topped off bro
Nathan - #425 - 07 Yamaha R6
35 Motorsports, Vortex Racing, Pit Posse Motorsports, Spy Optics, Suomy Helmets, 614 Paintworx, Optimal Racing, GP Tech
Nationwide Children's Hospital/Ohio Motorcyclists for Children
The Retrofit Source
natedogg624 is offline
post #4 of 12 (permalink) Old 12-18-2012, 06:10 PM
Bike: 2004 R6, 2004 R6 Tracker
Re: Blinker problem
did you trace the wiring down and check the grounds?
"When life throws you a curve... lean into it"
skennedy1023 is offline
post #5 of 12 (permalink) Old 12-19-2012, 07:08 AM
nova r6
tdoss1980's Avatar
Bike: 05 r6 Camo/Orange
Re: Blinker problem
Did it just start out of the blue or did you install the flushmounts or the integrated taillight and then it started happening? Because the R6 has 3 wire front turn signals oem and flushmounts mostly only use 2 (ground and the power for the turn signal to flash, and at least on my integrated it used only the ground from the taillight itself not the ground for each signal for the whole housing then you just need the proper positive wires installed.
March 2014 Bike of the month
tdoss1980 is offline
post #6 of 12 (permalink) Old 12-19-2012, 09:43 AM
bleed Yami
Dewey's Avatar
Bike: 06 R6(track), 10 Z1000
Re: Blinker problem
Dewey is offline
post #7 of 12 (permalink) Old 12-19-2012, 12:03 PM Thread Starter
scibona55's Avatar
Bike: 2005 Raven
Re: Blinker problem
I bought the bike with the intergrated lights... its been doing it since I bought the bike regularly but every once in a while the signals will function properly.
post #8 of 12 (permalink) Old 12-19-2012, 12:06 PM
Official Noob Greeter
redisdeadrideblue's Avatar
Bike: stupid ones and a Prius
Re: Blinker problem
Blinker fluid is low.
Here. Get some of this.
redisdeadrideblue is offline
post #9 of 12 (permalink) Old 12-19-2012, 12:06 PM Thread Starter
scibona55's Avatar
Bike: 2005 Raven
Re: Blinker problem
post #10 of 12 (permalink) Old 12-19-2012, 01:18 PM
Live ride die
animal1000's Avatar
Bike: 08
Re: Blinker problem
Was told 99% of the time its the rear lights that cause the problems....
It was like riding an Epileptic fit...
animal1000 is offline
03 blinker problem 2GrandMan Garage / Mechanical Help 3 06-04-2012 04:05 PM
Magic Blinker Problem Snapshot Appearance and Exterior Mods 16 03-04-2012 04:56 PM
blinker and drl problem Craig14122 Appearance and Exterior Mods 2 07-12-2010 05:47 PM
blinker problem trickysr6rocket Garage / Mechanical Help 2 05-30-2008 10:10 PM
Problem With Rear Blinker lights? Help? purebordom Appearance and Exterior Mods 13 07-10-2007 02:58 AM
