Hello everybody I'm new to the forum and in need of some help I've look all over the Internet can't find anything.My bike is a 2006 r6 I got into a crash a lower slide on the twist so after getting my bike back home it will not start I turn the key on and my cluster gauge works no engine but my fuel pump doesn't come on and when I hit the start button nothing happens it won't turn over or anything...Things I have checked fuses, clutch, kickstand, kill switch,tip over sensor, also I fell on the left side and broke my fairing stay snap my headlight... any ideas please I need help sorry for a long post but I thought I'll cover everything
Are you getting error codes? Check the fuses. If not start tracing the starter motor circuit and see where it is/isnt getting power. Grab the service manual either way.
No error codes.ill check the starter circuit to see if it's getting any power...check ignition fuse it was good don't have a voltage tester can I buy one from auto zone
Find out the problem connection to right side control got disconnect after my fall snap it back into place and my fuel pump came on hit the starter button then voom hope this help
Related Threads
3.1M posts
112.1K members
Since 2003
