520 Conversion Pros And Cons - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 16 (permalink) Old 01-15-2007, 10:06 AM Thread Starter
Ride Like Hell
enlawlis's Avatar
Bike: 2004 Yamaha R6
Images: 1
I know there are some pros and cons to the 520 conversion. Does anyone have any input for someone wanting to do this.
enlawlis is offline
post #2 of 16 (permalink) Old 01-15-2007, 10:09 AM
STOP PROJECTING ON ME@!!@
Captscooter 954 R6's Avatar
Bike: 2002 954, 2006 R6
Re: 520 Conversion Pros And Cons
you should have done a search. but at any rate it is less weight and rotating mass on the driveline. i did a -1 and +3 and it is awsome. it will last just as long as a stock setup as long as it is installed properly and maintained by lubing the chain once in a while. really no major drawbacks.
2006 RAVEN-Full Yosh TRC Carbon System. Graves Block-Off Plates, PC3 USB, Shogun No-Cut Frame Sliders, Speedo Healer, Greggs Customs Front Flush Mounts. Powdercoated Pass. Pegs and Rearsets. Zero Gravity Clear Dubble Bubble. CRG Shorty Roll-A-Click Levers in Black. Michelin Pilot Power 2CT Front and Rear. EBC HH front Pads. Galfer Black Brake Lines. Acumen Digital Gear Indicator. GYTR Filter. Tuned Stock Suspension. Integrated Rear Turn Signals into Pass. Pegs with L.E.D.s
Captscooter 954 R6 is offline
post #3 of 16 (permalink) Old 01-15-2007, 10:34 AM
Silver bullet jockey
04areSix's Avatar
Bike: 04 R6 - Liquid Silver
If you change your gearing, your speedometer and odo will be out. But that's minor. These bikes arn't meant for high mileage anyways, so ride the snot out of them while they're young! Anyways, that'd be the only drawback. I'd suggest play with the gearing and do the swap yourself.
2004 Liquid Silver R6
04areSix is offline
post #4 of 16 (permalink) Old 01-15-2007, 12:58 PM
crashing aint so bad
luke geis's Avatar
Bike: 2005 red r6
Images: 10
there are no drawbacks to a 520 conversion using the stock gearing. if you go with the popular -1 +2 set up the only difference is your speedo will be off a couple m.p.h and you will be doing about 6000 rpm at 60, 7000 at 70,and so on, so it will be a little bit of a rever on the freeway. it would be about the same as if you were cruising in fifth gear with stock gearing. I usually find myself in forth or fifth anyway when doing a short jaunt as i like to see the tack at around 7-8 g never lower than 6g when on the freeway or city streets.
luke geis is offline
post #5 of 16 (permalink) Old 01-15-2007, 12:59 PM
Custom User Title
Daredevil's Avatar
Bike: Built 08 r6 race bike
Send a message via AIM to Daredevil
you're joking right?
i know and have heard of TONS of guys who are pushing 50K on their odo's on yamaha's. even guys who have hit 100k and still goign strong wtf are you talking about...
r6's should last you 100k miles if properly maintained.
Daredevil is offline
post #6 of 16 (permalink) Old 01-15-2007, 01:08 PM
luke geis's Avatar
Bike: 2005 red r6
Images: 10
true dat. true dat.
post #7 of 16 (permalink) Old 01-15-2007, 03:41 PM
Super Mod
mx3TT's Avatar
Bike: 05 R6
Images: 1
Send a message via AIM to mx3TT
plus you guys forgot to mentio the SPEEDOHEALER which will fix your speedo probs. there is no drawback. buy it and have fun
RED 2005 R6
Racefit Growler - Solo Exhaust Bracket - Lockhart Phillips No Cut Carbon Fiber Frame Sliders - Lockhart Phillips Carbon Fiber Swingarm Sliders - Puig Tinted Double Bubble Windscreen - Pirelli Diablo DRC - BMC Air Filter - Shift Shaft Support - Dyno Jet Power Commander 3 USB - Yamaha Factory Seat Cowl - Factory Pro +4 Ignition Advancer - Graves Slide Stops - 520 Conversion(-1,+2) AFAM/DIDERV3 - Graves Smog Block Off Plates - Speedo Healer - GPR Steering Damper - Dyno Jet Quick Shifter
mx3TT is offline
post #8 of 16 (permalink) Old 01-15-2007, 07:26 PM
I fling poo!
Monky's Avatar
Bike: 03 r6
Send a message via AIM to Monky Send a message via MSN to Monky Send a message via Yahoo to Monky
Only drawback I have to mention for the 520 is keeping my damn chain clean! Stupid dirt!
It's better to be hated for who you are than to be loved for who you're not.
Jesus rode a Harley --- It says in the Bible ---- "He was always walking here -- and always walking there".
Monky is offline
post #9 of 16 (permalink) Old 01-15-2007, 07:38 PM
Riding his own ride...
gsxcorey's Avatar
yes a speedohealer will solve those problems...
the bikes can easily handle high mileage also. my r1 has 45k with a big bore kit and HARD riding and every mod on earth done almost
Corey
gsxcorey is offline
post #10 of 16 (permalink) Old 08-09-2012, 07:29 PM
Lifetime Premium
recondaddy's Avatar
Bike: 09 R6
depending on the how you change the teeth it runs through the revs and is always reving high. If you plan on racing neither are cons and there are none.
2009 R6 - Full exhaust, gold click-a-roll shorty levers, pc5 w/ custome tune, 520 with -1+2, pro grips, carbon fiber engine covers, all lights intergrated
recondaddy is offline
Pro's Con's with 02 R6 roushrider81 General Discussions 3 11-01-2006 12:01 PM
Pros. and Cons. to R6 and GSXR 600 roushrider81 General Discussions 15 10-13-2006 07:18 AM
help please.. pros and cons on this exhaust!! motofreak03 Exhaust and fuel delivery 1 09-26-2006 01:39 AM
