Bike won't stay running - Yamaha R6 Forum: YZF-R6 Forums
 1Likes
  • 1 Post By Flyers28
post #1 of 6 (permalink) Old 05-16-2017, 05:27 AM Thread Starter
Hello I recently replaced my battery in my 2014 r6 and after I changed the battery the bike wouldn't stay running unless you held the starter in does anyone have any idea what it could be I changed the stater relay switch and still no luck thanks in advance
Jacob Clark is offline
post #2 of 6 (permalink) Old 05-17-2017, 06:25 PM
Bike: 05 r6
Re: Bike won't stay running
If it starts then die, it could be two things, the charging system, or something with the fuel system. I have something similar on my 2005 r6. I felt the battery was so weak to start the bike, when finally started I drove few feets then turned the signal then boom died again, started it again drove for a mile or so the the numbers on the display started to flicker then vanished, then the throttle was not giving enough gas then died. After that I couldn't start it again, I charged the battery , rode it few hours with no problem then the same issue returned again, I found that I have a bad charging system and am working on it now, I guess the r6 needs electricity to stay running.
I am not an expert, just giving thoughts
Eugenian is offline
post #3 of 6 (permalink) Old 05-17-2017, 06:27 PM
Bike: 05 r6
Or u could check ur wires, take to a shop to not waste ur time and money
Eugenian is offline
post #4 of 6 (permalink) Old 05-17-2017, 07:26 PM
make sure all wires are seated correctly on the battery terminals, make sure there is not any type of debris on the contacts like corrosion or rust build up. if that does not fix it go into diagnostics mode and see what the voltage is and then try to start it and see if the voltage drops drastically.
after you have tried all that and voltage looks good then move onto the fuel system. more then willing to help you out and walk ya through it.
my bike not running the way i want drives me nuts. so i feel ya
R6leanslikeacholo is offline
post #5 of 6 (permalink) Old 05-18-2017, 06:15 AM
~C@TcH mE iF U c@N~
tones160's Avatar
Bike: 05 R6 - Cherry
If that only happened because you replaced your battery then im thinking there's a bad connection along the terminals. Unhook it and hook it back in and see how it works. If problem still persist check your R/R and its plug for any indication of burning.
tones160 is offline
post #6 of 6 (permalink) Old 05-18-2017, 09:08 AM
Flyers28's Avatar
Bike: 07 Candy Red R6
I feel like some info is missing here and lacks some background info. Was the bike working perfectly prior to replacing the battery? What led to replacing the battery in a relatively newer bike (ie: sat for long periods without running and with battery connected to bike)? You say running, just to clarify you mean engine turns and fires right.
You need to get out the multimeter and check the battery voltage and post your results for starters. While it could be a charging system malfunction I find it hard to believe a stator or rectifier goes bad in a 3 yr old bike.
But without the OP coming back to fill in more details this thread will be nothing but vague speculations and dead ends.
tones160 likes this.
Flyers28 is offline
07 r6 won't stay running Powell939 Garage / Mechanical Help 6 07-29-2016 02:58 PM
Won't stay running motoman21 Garage / Mechanical Help 65 03-27-2013 04:44 PM
04 R6 won't stay running Fastass111 Garage / Mechanical Help 3 10-27-2012 02:46 PM
Bike won't stay running I need help! roblee8908 Exhaust and fuel delivery 10 07-01-2009 11:15 PM
My bike won't stay running. njk27 General Discussions 5 07-28-2005 02:14 PM
