Disconnected stator test - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 6 (permalink) Old 05-17-2017, 02:06 PM Thread Starter
Bike: 05 r6
Hi guys,
This is my first post here. Just joined because I found a lot of useful posts that can help us fixing our bikes with no need to take to a shop, thank you guys.
Anyway, I have a charging issues with my 2005 r6. I changed the battery but still having the same problem which is a dead battery after riding, each time after fully charged. I got a new stator I thought it's what causing the problem. I saw a Video on YouTube when measuring his disconnected stator he got 0.4 ohms on the new one and 0.1 on the old one.
I did the same , I think, but both of my readings are 0 ohms. Now I don't know if it's the stator or some else. I am waiting for a new gasket to reinstall everything and start the bike.
But for now, is there any way to know that the problem is from the stator or something else while disconnected?
Thanks
Eugenian is offline
post #2 of 6 (permalink) Old 05-17-2017, 02:10 PM
lostinthesmoke's Avatar
Re: Disconnected stator test
Have you tried testing the rectifier?
Sent from my SM-G930P using Tapatalk
lostinthesmoke is offline
post #3 of 6 (permalink) Old 05-17-2017, 03:02 PM Thread Starter
Bike: 05 r6
I don't know how ? Just a reminder the stator is not connected now
Eugenian is offline
post #4 of 6 (permalink) Old 05-17-2017, 03:06 PM
Here's a video check it out.
post #5 of 6 (permalink) Old 05-17-2017, 05:54 PM Thread Starter
Bike: 05 r6
Thank you
Eugenian is offline
post #6 of 6 (permalink) Old 05-18-2017, 06:56 PM
Just lean harder...
Phrozen's Avatar
Bike: 07 R6s
First you need to check to see if any one of the 3 stator wires show any continuity to ground. If it does it's shorted to ground and is toast. Replace stator and regulator.
If it's not shorted to ground you need to start the bike with the stator upluged. You should get around 18-20 volts AC at idle across the three wires any way you test them putting the probes on wires 1&2 or 1&3 or 2&3 the voltage should go up if you rev the bike.
If the stator isn't shorted to ground and is marking AC voltage across all 3 wires but it still isn't charging replace the Voltage Regulator/Retifier.
Make sure you inspect the wires on the bike harness and of course the plugs for any burns or melting. If the wires have gotten too hot just wire the stator straight to the regulator and then the regulator straight to the battery without using the wires in the bike harness itself.
Phrozen is offline
Rear brake is 'disconnected' thor310 Garage / Mechanical Help 3 08-31-2011 01:33 PM
What would happen if I left it disconnected? Irillus Garage / Mechanical Help 2 10-07-2008 12:17 PM
'01 R6 stator test madmax Garage / Mechanical Help 4 09-22-2006 05:22 PM
To all those with a 06 with X-up disconnected Orlando06R6 Exhaust and fuel delivery 12 06-22-2006 04:08 AM
