Ignition advancer? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 20 (permalink) Old 11-11-2003, 02:03 PM Thread Starter
Ignition advancer?
Has anyone here installed an ignition advancer or even know someone who has or even know if you can get one in the UK?
Speedfreek
speedfreek is offline
post #2 of 20 (permalink) Old 11-11-2003, 07:47 PM
Send a message via MSN to penfold
If you have a '99-'02, you can order one from Graves. Don't know how much shipping would be but I'd have to think that with the strength of the Euro, it's be pretty cheap. $52.00 USD and they have 5% off for online orders but it takes a while for them to respond to them. I submitted my order for Velocity Stacks about a week ago and just today they acknowledged reciept of my order and are sending them out tomorrow.
penfold is offline
post #3 of 20 (permalink) Old 11-11-2003, 09:03 PM
What does this do??
Whatdo velocity stacks do??
"Treat it like you love it , ride it like you hate it"
PEOPLE WHO THINK THEY KNOW EVERYTHING ANNOY THOSE OF US THAT DO!
jasamb is offline
post #4 of 20 (permalink) Old 11-12-2003, 01:54 PM Thread Starter
An ignition advancer does exactly what it says on the tin - it advances the ignition timing. This usually boosts low end and mid range power and smooths it out a bit. You're also supposed to get sharper throttle response.
It tends to boost partial throttle opening power. That's why the effects aren't always clear from a dyno run (full throttle, blast the nuts of your bike type situation).
I believe that there are two types available for the R6. A standard +4 degree ignition advancer and a fancy variable advancer that needs to be tuned. +4 might be a tad too much for this bike.
Also, they have been know to actually lower the peak power and obviously, huge advances can damage the engine.
Speedfreek
post #5 of 20 (permalink) Old 11-12-2003, 03:11 PM
Originally Posted by jasamb
What do velocity stacks do??
Velocity stacks help to reduce turbulence and increase airflow into the engine. It should allow for more air to flow into the intake that without them creating more pressure and pushing more air/fuel into the engine there by giving more power. Of course, without an air filter and exhaust with a higher flow rate than stock, they're kind of useless. I ordered some from Graves that should be here this wek. Plus my Blue Flame 3D Silver Carbon slip on came yesterday and my BMC Race air filter should be here next week sometime. To bad it's to cold out to go test it with the mods going on. Hope to get a powercommander over the winter and then come spring time, a custom map for it.
You've probably seen them one custom choppers before ala.....
with the megaphone style billet piece being the V Stack..
one with an air filter....
these are what the Graves stacks look like inside the airbox......
penfold is offline
post #6 of 20 (permalink) Old 11-12-2003, 06:59 PM
So is this something you can just bolt on in place of the stock ones or slip over or inside the stock ones or do you need to dyno the bike to get them in the correct position..
The reason I ask is that I have my airbox off now and the carbs are right there. This seems like something I "might as well do" while the thing is apart.
Yea, or no??
jasamb is offline
post #7 of 20 (permalink) Old 11-12-2003, 10:07 PM
now would be the time to do it but they are only for the FI bikes. And they just bolt in place on top of the throttle bodies and enter into the airbox to smooth out the airflow, especially at high speeds. Factory Pro makes V Stacks as well but I don't know if those are also only for FI bikes.
penfold is offline
post #8 of 20 (permalink) Old 11-13-2003, 10:33 AM
What about, I think theyre called..."slide stops" or something like that???
Are those related to carburators.
**carbs are the only part of this bike that I do not fully understand, I mean I know how they work, but it is the one area that I have little experience with.**
jasamb is offline
post #9 of 20 (permalink) Old 11-13-2003, 11:23 AM
again, they are for FI bikes only but this is what they do. Taken from Graves Website (
Graves Motorsports Throttle Slide Stop Kit has been designed to hold the throttle slides in the fully open position while increasing fuel pressure in the injectors fuel rail. The outcome is improved throttle response and increased acceleration. The kit comes complete with comprehensive installation instructions and a selection of fuel maps for the Dynojet Power Commander, to suit your specific application. (Note the Graves Slide Stop kit must be used in conjunction with a Dynojet Power Commander.)
From the sounds of it, they just keep the throttles bodies open more at any given point on the rotation of the throttle than stock. But I'll email Graves and ask them more specifically how they work.
penfold is offline
post #10 of 20 (permalink) Old 11-11-2012, 02:10 AM
cvs
Re: Ignition advancer?
hello my friends i m new in this forum and i wish to ask anyone please where i can buy an ignition advancer for my yamaha r6 2000 model cause i can t find it anywhere every one is telling me they stopped the production of it could you help me and i m from malta buy the way
cvs is offline
Stuck ignition The_RippeR Garage / Mechanical Help 4 10-06-2006 01:42 AM
Ignition Lock Question MiaRay General Discussions 2 03-09-2006 08:11 AM
need help with ignition advancer flacosr6 Garage / Mechanical Help 11 12-21-2005 02:40 PM
FBF (Fast By Ferracci) Ignition Advancer Titus62 General Discussions 0 09-14-2005 11:47 AM
FZ6/R6 ignition advancer question. also HC shift support.. phxtravis General Discussions 3 06-22-2005 07:17 PM
