What is the torque spec for rear sprocket??? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 10 (permalink) Old 04-02-2009, 01:42 PM Thread Starter
2007 R6
Yam07R6's Avatar
Bike: 2007 Track R6
Images: 1
Anyone have the torque spec for the rear sprocket nuts??? Also any idea on the front rotor bolts. I can't seem to find them anywhere. Thanks for any replies.
2007 R6 - O2 Carbon Tank Cover, GYTR Carbon Fiber rear tire hugger,Carbon Fiber Swingarm covers,Carbon Fiber Front Fender, MCarbon side covers, MCM Carbon Fiber Stator Cover and Clutch Cover, Ohlins Rear Shock, Ohlins Fork Internals and Seals, Yoshimura Header w/ DTC Carbon Pipe, Dynojet PCIII, Driven F/R Sprockets +2 Rear and -1front, Carbon Fiber heel guards, Tuner X Frame Sliders, Pazzo Levers, RK 520 Chain, BMC air Filter,Rizoma Grips and Bar Ends, GPR V4 Damper, Woodcraft Rear sets,DMS Rear Wave Rotor, Galfer Brakelines, BT003 Race Tires, Ferodo Brake Pads,PIT-ECK Race Body,
Yam07R6 is offline
post #2 of 10 (permalink) Old 04-02-2009, 03:17 PM
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
Re: What is the torque spec for rear sprocket???
service manual says 72... but i'd be VERY careful if you decide to take it that high. me and one other dude that i know did it successfully but another two broke AT LEAST one bolt off (one of em broke THREE). i'd feel safe at the 60 mark with loctite. good luck.
Agg2001 is offline
post #3 of 10 (permalink) Old 04-02-2009, 06:13 PM
Lifetime Premium
michaelrc51's Avatar
Bike: R6
Send a message via AIM to michaelrc51
No loctite needed, they are locknuts. Just torque them down, they won't loosen up.
michaelrc51 is offline
post #4 of 10 (permalink) Old 04-02-2009, 06:15 PM
STOP PROJECTING ON ME@!!@
Captscooter 954 R6's Avatar
Bike: 2002 954, 2006 R6
guten tight.. its a german spec..lol
2006 RAVEN-Full Yosh TRC Carbon System. Graves Block-Off Plates, PC3 USB, Shogun No-Cut Frame Sliders, Speedo Healer, Greggs Customs Front Flush Mounts. Powdercoated Pass. Pegs and Rearsets. Zero Gravity Clear Dubble Bubble. CRG Shorty Roll-A-Click Levers in Black. Michelin Pilot Power 2CT Front and Rear. EBC HH front Pads. Galfer Black Brake Lines. Acumen Digital Gear Indicator. GYTR Filter. Tuned Stock Suspension. Integrated Rear Turn Signals into Pass. Pegs with L.E.D.s
Captscooter 954 R6 is offline
post #5 of 10 (permalink) Old 04-02-2009, 06:15 PM
Agg2001's Avatar
i was only saying use loctite since specs say 72, but he'd only be going to 60 or so. i'm just glad i GOT mine there w/o breaking any lugs off.
Agg2001 is offline
post #6 of 10 (permalink) Old 04-02-2009, 06:17 PM
Lifetime Premium
Bike: R6
I see now..
post #7 of 10 (permalink) Old 04-02-2009, 07:17 PM
pop wheelies
AirManCam's Avatar
Bike: 2010 R1
Send a message via AIM to AirManCam
Tight is the spec
I tighten mine up as tight as I can with a 3/8 ratchet 14k later still no problems and I've done it about 10 times.
AirManCam is offline
post #8 of 10 (permalink) Old 04-02-2009, 09:38 PM
Will work for track time
redwood650's Avatar
Bike: An orange one
Be careful with the rotor bolts, they have loktite on them. I learned that the hard way when I took my rotors off a long time ago.
redwood650 is offline
post #9 of 10 (permalink) Old 04-02-2009, 09:43 PM
dirtslayer's Avatar
Bike: 08 r6 mi"S"take
ya, its best to get a torch on the rotor bolts to melt te loctite first.
also, you cannot get a proper torque reading when there is loctite on the bolt or stud, thats why you have had broken studs.....................
2008 R6S Blue, Integrated tail, Flushies, blacked Screen, Black stomp grip, vortex sliders, 2008 r6r bronze wheels, black shorty exhaust, crg levers, bridgestone 002rs, EBC pads, custom drilled rear rotor, clip-ons moved beneith top crown, radar detector...
dirtslayer is offline
post #10 of 10 (permalink) Old 04-07-2009, 04:20 PM Thread Starter
2007 R6
Yam07R6's Avatar
Bike: 2007 Track R6
Images: 1
Thank You everyone for the reply. I will shoot for 60-65 ft lbs. Thanks Again.
Yam07R6 is offline
2007 torque specs question (drive sprocket and axle nut) rideblue450 Garage / Mechanical Help 5 03-12-2010 07:05 PM
03-05 r6 sprocket install torque specs?? baggedb22 Garage / Mechanical Help 2 04-14-2008 09:23 PM
Rotor bolt torque spec DealsGapR6 General Discussions 1 11-10-2007 06:05 AM
Torque Spec Help. GET CARTER General Discussions 4 08-21-2007 10:19 AM
06 Front sprocket torque and rear sprocket torques? gawarrior General Discussions 10 05-04-2006 09:48 AM
