Marchesini front rim - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 24 (permalink) Old 12-22-2011, 05:58 PM Thread Starter
1 USED alu marchesini 5Y front rim, for 02-03 R1.
no rotors, complete with spacers.
powdercoated white. 1 single chip, inside rim where tire bead sits.
asking $530 shipped.
Here's the deal, i bought it to try to retrofit it to my 06 R6V, but i failed to see that the older R1/6 used 6 bolt rotors, not 5 like the newer ones.
I have test fitted it to my R6V and it fits perfect, SO, if you have oversized pre 04 R1 rotors, that are 320mm you can run this on a new R6 with 5mm spacers at the calipers.
If you have 310mm pre 04 rotors youre golden.
If you have a 00-03 R6 or R1, these will bolt on fine and use stock rotors.
Im still attempting to get a Marchesini accessory kit so i can make it fit my R6V, but no luck so far, if i get one, it will no longer be for sale, but in the mean time. its up for grabs.
Name:	Alu March front (5).jpg
ID:	71240   Click image for larger version
Name:	Alu March front (4).jpg
ID:	71241   Click image for larger version
ID:	71242   Click image for larger version
ID:	71243   Click image for larger version
snik is offline
post #2 of 24 (permalink) Old 12-22-2011, 06:37 PM
A work in progress...
TheJokester3's Avatar
Bike: 07 Candy Red R6
Re: Marchesini front rim
That is a beautiful rim. GLWS
RIP Matt (Ghost R6). You will be greatly missed. Be smooth and the rubber turning till we meet again.
"I refuse to tip toe through life to arrive safely at deaths door".
Originally Posted by thedub View Post
There is more to squidliness than just your gear.
TheJokester3 is offline
post #3 of 24 (permalink) Old 12-23-2011, 08:16 AM Thread Starter
Thank you. bump.
F/S:
Alu 5Y rim.
snik is offline
post #4 of 24 (permalink) Old 12-26-2011, 08:21 AM Thread Starter
bump...
F/S:
Alu 5Y rim.
snik is offline
post #5 of 24 (permalink) Old 12-28-2011, 08:37 PM Thread Starter
Bumpy.
F/S:
Alu 5Y rim.
snik is offline
post #6 of 24 (permalink) Old 12-28-2011, 08:46 PM
Is this a segment?
imaking20's Avatar
Bike: Vengesicle
Braketech rotors
Rest in Peace - Jason "Snocompton" Jones 2/23/87 - 11/4/11
imaking20 is offline
post #7 of 24 (permalink) Old 12-28-2011, 09:21 PM
ntbush83's Avatar
Bike: 2002 YZF6
Wish I had a rear to match...
2002 R6
- Vortex 520 -1,+2 Orange EK
- Powder coated wheels and sets
- Shorty levers
- rear EBC rotor and pads
- frame sliders
- angled valve stems
- rossFAB license plate bracket
- Danmoto carbon exhaust
ntbush83 is offline
post #8 of 24 (permalink) Old 12-28-2011, 10:05 PM Thread Starter
Originally Posted by imaking20 View Post
Braketech rotors
If I could this wouldn't be for sale. Believe me.
F/S:
Alu 5Y rim.
snik is offline
post #9 of 24 (permalink) Old 12-28-2011, 10:08 PM
Is this a segment?
imaking20's Avatar
Bike: Vengesicle
I'm sure they make a rotor that will work. They're sweet
post #10 of 24 (permalink) Old 12-28-2011, 10:15 PM Thread Starter
The problem is relatively easy to fix if I can't source a carrier to fit.
Get oversized pre 03 R1 rotors, usually 320mm and machine these carriers down 2.5mm each side. Add caliper spacers, done.
The wheel actually fits my R6V. Problem is pre 03 rotors are like 298mm and 5mm wider L rotor to R rotor.
If someone has big pre 03 R1 rotors, some simple carrier machining, and spacers these would fit great.
I just can't afford a set of those rotors right now.
F/S:
Alu 5Y rim.
snik is offline
Wanted: Marchesini front wheel fusion Bikes + Parts + Gear Wanted 2 08-08-2011 11:47 AM
WTB: 06+R6 or 04+R1 Front Marchesini ducracer081 Bikes + Parts + Gear Wanted 0 03-16-2010 10:15 AM
05 Marchesini's shaneislooney Appearance and Exterior Mods 1 01-25-2008 08:10 PM
marchesini wheels? tomcatusaf Appearance and Exterior Mods 0 01-07-2007 03:45 AM
Marchesini / Brembo / Marchesini????? dmccarley1979 General Discussions 2 06-15-2006 09:01 AM
