How to connect turn signal? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 6 (permalink) Old 05-06-2010, 11:14 PM Thread Starter
is trying to find BP!!
HaynMoGLi's Avatar
Bike: 03 R6 stunted
bought these rear turn signals...looks like it has oem connector but doesn't look like my bike has the oem connector. how can i connect it?
turn signal connecter piece:
wire i have that run to the tail for signals and what not:
HaynMoGLi is offline
post #2 of 6 (permalink) Old 05-06-2010, 11:26 PM
Re: How to connect turn signal?
those plastic pieces look to be butt splices. pull/cut them off to expose the wire. cut the connector from the signal and expose the 2 wires. connect black to black...and then the brown on the signal to either brown/green (right light vs left light) on the bike. use heat shrink or new butt splices to cover the exposed wire.
trilai is offline
post #3 of 6 (permalink) Old 05-07-2010, 01:14 PM Thread Starter
HaynMoGLi's Avatar
Bike: 03 R6 stunted
yeah they are...just wish i had the oem connectors...anything out there i can connect wires to that allow quick disconnect and connection? for when i want to take those parts off for stuntin
post #4 of 6 (permalink) Old 05-07-2010, 09:05 PM
Bike: 2001 R6, 2004 STi
use anyone of these:
preferably the matching end to what you already have on the bike to save you half the work.
any home improvement center would have them, as will radio shack. if you're lucky, bring your bike over to radio shack and the guy will prolly help you/tell you how to do it.
48mpg is offline
post #5 of 6 (permalink) Old 05-10-2010, 06:37 PM
Bike: 2005 R6
I have connected my turn signal, but it doesnt work. I checked the fuse, but thats not the problem. So what's likely to be the concern?
ballballfu is offline
post #6 of 6 (permalink) Old 05-10-2010, 07:04 PM
check your ground. on my bike, its the black wire.
next check that you have power going through that wire when you turn on the blinker.
48mpg is offline
Turn signal difficulties tnight47 Appearance and Exterior Mods 10 03-26-2010 09:32 PM
Turn signals disable headlights? tseuG Appearance and Exterior Mods 6 05-04-2008 08:05 AM
turn signal connector zing General Discussions 9 09-06-2007 09:46 PM
Turn signal trouble! Help! platinumfist New Member Section 4 09-01-2007 06:29 PM
TURN SIGNAL QUestion--- 2001 yamaha R6 silver11 How To's... 4 01-08-2005 10:27 PM
HTML code is On
