Holy Jesus that's a big picture. In my opinion I wouldnt get the lights, but that's just my .02 cents...It reminds me too much of every ricer that revs his engine when I pull up next to him. But hey, to each man his own.
i was thinkin of doin a CCFL setup also...how many did you use and where did you put them (i can think of 4 maybe 5; front, rear, sides, maybe bottom) also how did you do the wiring....better yet why don't you make up a "how-to" thanx
7 CCFL's switched through 1 switch flushmounted on the ram air cover. The inverters are beneath these for the side/front CCFL's and under the seat for the Suspension tail CCFL's. I used voltage regulators for each inverter. 4 in all.
Wiring is simply 12 from the battery to one side of switch. From there split to each inverter. Each inverter has its own 7812 voltage regulator because bike makes 14 volts while running. Didn't want to risk the inverters.
so lets see...1 in front, 1 on each side, 2 under tail and...2 on bottom? i can see more or less where the first 5 are but not the last 2 (because i can't see bottom of bike)
1 tail under rego plate
1 just behind battery tray above suspension
Inverter for these under seat
2 on each side 1 vertical in front of vent 1 horizontal below
1 on under & behind ram air ducts on front
Inverters for these 2 under left ram air cover with switch 1 on right
All up 7
Still to be done
I am going to spray headers with high temp silver and put 1 more in the vertical bit of the small v shaped fairing on lower front.
Blue LED's behind all the smaller vents in the fairings and 2 maybe 4 drilled and mounted in the ram air ducts shining out of the front duct.
looks phat, if someone could make a proper idiots how too on this that would be great!
Related Threads
3.1M posts
112.2K members
Since 2003
