Flush mount USB port to power iPhone - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 11 (permalink) Old 10-27-2012, 10:12 AM Thread Starter
mick86's Avatar
Bike: 2008 Yamaha YZF-R6
Arrow Flush mount USB port to power iPhone
Not sure if this is the right section for this but I was considering doing something like the below link:
Has anyone else attempted this, where did you draw power from and where did you mount the USB port?
I was considering drawing accessories power from the horn, headlights or something in that vicinity and mounting the USB port on the plastic panel under the handle bars, I don't know the name of this panel.
Plan to combine this with a mount such as this:
Then add a cradle that will attach to my iPhone.
Hoping to hear from some more experienced bike modifiers, I'm more used to working with cars.
Mick.
mick86 is offline
post #2 of 11 (permalink) Old 10-27-2012, 10:31 AM
Lifetime Premium
Bike: 2007 Charcoal R6
Re: Flush mount USB port to power iPhone
It would be much easier and probably about the same cost to buy a 12V iphone charger and just hard wire it in. Even with the rubber plugs, I'd be concerned with water shorting out the USB with the linked method.
buddahson is offline
post #3 of 11 (permalink) Old 10-27-2012, 11:22 AM
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
Princess Auto (canadian store I believe), sells waterproof USB ports that work great. They don't "fast charge" the iDevices but work great otherwise.
Works sweet.
-Jamie M.
toysareforboys is offline
post #4 of 11 (permalink) Old 10-27-2012, 11:40 AM
lolerbaiting
elbaldwino's Avatar
Bike: 2007 YZF-R6
I just hardwired a car charger to the battery. You can get a universal one for like $12 from radio shack. I broke the traditional cigarette lighter housing and hard wired it to the battery. I did add a fuse just in case. Have had no issues in the rain and it charges my phone just fine.
"I come in peace, I didn't bring artillery. But I am pleading with you with tears in my eyes: If you **** with me, I'll kill you all"- Gen James Mattis
How to install Shermoto levers
elbaldwino is offline
post #5 of 11 (permalink) Old 10-28-2012, 02:12 AM Thread Starter
mick86's Avatar
Works sweet.
-Jamie M.
I had come across this model elsewhere albeit at a more expensive price
Seems the conses is that the project i was considering may look nice but possibly isn't robust enough for wet weather.
Did those of you who wired something up run the cables all the way from the battery and along the side of the tank or did you opt to take power fro ma source up near the instrument cluster? Ideally I'd liek the end result to look clean and as close to OEM as possible.
mick86 is offline
post #6 of 11 (permalink) Old 10-28-2012, 02:14 AM Thread Starter
mick86's Avatar
I also looked into options like this:
mick86 is offline
post #7 of 11 (permalink) Old 10-28-2012, 09:21 AM
Will Work For Bike
ReasonableDoubt's Avatar
Bike: 2005 R6; 2006 R6 - A.E.
Get something like this:
As other have said, it's easiest & more efficient to install a "cigarette lighter" adapter, plus your phone would charge faster than via USB. 5-10 min job and costs <$12, including a cheap car charger from ebay.
ReasonableDoubt is offline
post #8 of 11 (permalink) Old 10-28-2012, 11:06 AM
Bike: 07 R1
Depends, if you only want it to charge when the bike is running you can wire it to the headlight wires up front for power. If you want it to charge when the bike is off you'd need to wire it right to the battery, with a switch and fuse.
-Jamie M.
post #9 of 11 (permalink) Old 10-28-2012, 11:37 AM
the Blue Meanie
Ralfferly's Avatar
Bike: 07 R-6 06 Road Warrior
If you go to auto zone you can get one for about $5.00 that has a rubber plug to protect from the weather. It will fit in a opening under the panel on left side under the handle bars. It is close to the tank and this is the most out of the way spot that I could find. Just the outlet, some wire connectors, wire, an inline fuse ans some shrink wrap to protect the outlet from grounding and weather proofing on the under side. Just measure like three times before you drill in to that plastic panel, you want to do it right the first time. I found any other spot would severely interfere with the handle bars movement. U-turns will get a little tight, but they were tight in the beginning. When I get home tomorrow, I will take photos of the area I am talking about and post them on here. I will not be able to take any completed product photos due to my bike getting smashed by a suburban last November. But good luck.
Ralfferly is offline
post #10 of 11 (permalink) Old 10-28-2012, 12:32 PM Thread Starter
mick86's Avatar
Thank you, pictures would be much appreciated. Sorry to hear about the crash :/
mick86 is offline
flush mount help! se7engtr Appearance and Exterior Mods 5 08-18-2010 06:39 AM
flush mount grantltaylor Appearance and Exterior Mods 0 08-02-2007 02:37 PM
K&S Flush mount kit Kevin B How To's... 8 04-16-2007 10:33 PM
Flush mount Q Probait Appearance and Exterior Mods 11 09-14-2006 07:08 PM
Blue Flame carbon fiber dual port high mount Hammy_The_Can_Man Site Sponsored Specials 2 10-11-2004 11:19 AM
HTML code is On
