Motodynamic nightmare - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 10 (permalink) Old 11-04-2012, 09:47 AM Thread Starter
I have tried to install a smoked Integrated tail light everything went smoothly until I reassembled the fairings. Then I realized the rear only flashed on 1 side non stop it wouldn't turn off and the other turn signal would not work. I switched the connector then the same problem in reverse. To make matter worse the 6 Phillip head plastic caps wont unbolt to remove the upper-tail fairing. I already broke 1. I am just disgusted with myself right now. I would appreciate any ideas
daddyo is offline
post #2 of 10 (permalink) Old 11-04-2012, 09:56 AM
Devsterman's Avatar
Bike: Charcoal '07
Re: Motodynamic nightmare
Do you have any pictures?
First, check the harness that came with the tail light. They should look like this. If not, correct it.
No Longer With Me. RIP
-1/+2, OURY Grips, Shermoto Levers, SKUR Triple Cover, OhioYJ Flashed ECU, Lamin-X Headlight Tint, AGG HIDs, Motodynamic Integrated Taillight, BMC Filter, ZG Double Bubble Windscreen, HotBodies Flushmounts, T-Rex Sliders/Spools/Bar Ends (Slow drop tested ), Competition Werkes LTD FE, GYTR Carbon Can, Bullseye Vinyls
Devsterman is offline
post #3 of 10 (permalink) Old 11-04-2012, 09:57 AM Thread Starter
The harness has 3 wires Red, black & white
daddyo is offline
post #4 of 10 (permalink) Old 11-04-2012, 09:59 AM
Devsterman's Avatar
Bike: Charcoal '07
Could you please take some pictures, and post them, so we can help you out a little more?
post #5 of 10 (permalink) Old 11-04-2012, 10:01 AM Thread Starter
will do
daddyo is offline
post #6 of 10 (permalink) Old 11-04-2012, 10:11 AM
r6sport's Avatar
Bike: 2006 Yamaha R6S
Pretty straight forward. Pics will help a ton! Have you looked at the "How-to"?
r6sport is offline
post #7 of 10 (permalink) Old 11-04-2012, 05:42 PM Thread Starter
Problem solved I was connecting the entire wrong things I didnt connect the black & grey plastic things I was plugging the metal connectors and leaving the plastic connectors free just a newbie messing up. I love the light
daddyo is offline
post #8 of 10 (permalink) Old 11-04-2012, 06:30 PM
motoman21's Avatar
Bike: '12 R6
What year is the how to for? Trying to install this on a '12
motoman21 is offline
post #9 of 10 (permalink) Old 11-06-2012, 03:17 PM
Bike: 2012 R6
just installed it on my 2012 a few weeks ago. pretty simple install, a true plug and play.. i did do some research on how to remove the old taillight before i actually bought it... you can find alot of good info on here and on youtube. some advise, if you are going to install a new tailight, buy a FE, if your going to change that as well... its easier to install both at the same time.
atxrider07 is offline
post #10 of 10 (permalink) Old 11-06-2012, 03:21 PM
motoman21's Avatar
Bike: '12 R6
Cool, seems easy enough. Just tight quarters, tiny trunk space.
Charging Nightmare Wraith1821 Garage / Mechanical Help 8 03-27-2010 09:09 AM
First Nightmare Kenneth84 Off Topic Talk 7 11-25-2009 09:50 AM
HELP! dealer nightmare! 03yamir6 General Discussions 26 04-23-2009 06:42 AM
What a fking nightmare... IGOR OT Appearance and Exterior Mods 21 07-06-2008 02:08 PM
Used 99 r6 nightmare python6586 General Discussions 5 07-20-2007 03:23 PM
HTML code is On
