Signal Problem - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 11-15-2012, 05:35 PM Thread Starter
Bugs in my teeth
HyOctane23's Avatar
Bike: 2005 Yamaha YZF-R6
Signal Problem
Hey gang...I have an 05 that is completely stock. One problem I have is that the flashers don't work correctly. I can push the switch to activate the left blinkers and they seem to have like a 2 second delay before they start flashing. When I hit the right blinkers, there is up to a 10 second delay then they start flashing. Any ideas? Maybe the switch is all gunked up inside?
HyOctane23 is offline
post #2 of 5 (permalink) Old 11-16-2012, 06:23 AM Thread Starter
Bugs in my teeth
HyOctane23's Avatar
Re: Signal Problem
Please help...my inspection is past due and I will not pass with this problem
post #3 of 5 (permalink) Old 11-16-2012, 06:43 AM
nova r6
tdoss1980's Avatar
Bike: 05 r6 Camo/Orange
Re: Signal Problem
Thats where I would start, and double check all the connections to the signals themselves, lastly if you can get your hands on a buddies flasher relay and try swapping that out as well
March 2014 Bike of the month
tdoss1980 is offline
post #4 of 5 (permalink) Old 11-16-2012, 06:48 AM Thread Starter
Bugs in my teeth
HyOctane23's Avatar
Re: Signal Problem
I think maybe if I take the swich apart and clean the insides? Would a faulty flasher relay cause a "delay" in the light activation? Thanks for the reply!
post #5 of 5 (permalink) Old 04-29-2014, 07:00 PM
FairladyZ33
Labelworkshop75's Avatar
Bike: 2006 50th R6
Re: Signal Problem
Old thread bump. I am having a similar problem. Left signal works fine, but the right signal is delayed. Only when it is cold out for some reason. If it is cold it takes 10-15 seconds to activate. If it above 80 degrees it works fine. Any ideas????
Labelworkshop75 is offline
04 turn signal problem schiff General Discussions 1 03-26-2011 11:02 AM
turn signal problem ccmsmackay Garage / Mechanical Help 3 09-10-2010 11:47 PM
R6S turn signal problem. please help! stantheman Appearance and Exterior Mods 6 05-28-2010 12:20 PM
yet another signal problem ZombieRider Appearance and Exterior Mods 2 04-07-2006 11:41 PM
signal problem!!! HELP gs430boy Garage / Mechanical Help 4 02-18-2006 04:15 PM
HTML code is On
