spark plug question - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 13 (permalink) Old 11-25-2012, 03:30 AM Thread Starter
spark plug question
If you let your bike sit the garage for many years. How long would you say before changing your spark plugs?
Noodleboy is offline
post #2 of 13 (permalink) Old 11-25-2012, 05:22 AM
Pastor of Muppets
yuengling910's Avatar
Bike: 09 R6, 07 R6S, 05 WR250F
Re: spark plug question
You should pull them and check them for condition. Couldn't hurt to just replace them. I would be worried about checking all of the fluids even more than the spark plugs though.
yuengling910 is offline
post #3 of 13 (permalink) Old 11-25-2012, 07:53 AM
gonzotheman's Avatar
Bike: 1981 CX500C 2012 Blue R6
Service manual recommends every 8k miles or every 12 months.
gonzotheman is offline
post #4 of 13 (permalink) Old 11-25-2012, 08:15 AM
Devsterman's Avatar
Bike: Charcoal '07
May as well replace them if you go through all the trouble just to get them out.
No Longer With Me. RIP
-1/+2, OURY Grips, Shermoto Levers, SKUR Triple Cover, OhioYJ Flashed ECU, Lamin-X Headlight Tint, AGG HIDs, Motodynamic Integrated Taillight, BMC Filter, ZG Double Bubble Windscreen, HotBodies Flushmounts, T-Rex Sliders/Spools/Bar Ends (Slow drop tested
), Competition Werkes LTD FE, GYTR Carbon Can, Bullseye Vinyls
Devsterman is offline
post #5 of 13 (permalink) Old 11-25-2012, 11:48 AM Thread Starter
If I do check them I'll probably change them but I don't know if I should check because I only have 3k on the bike.
post #6 of 13 (permalink) Old 11-25-2012, 11:52 AM
Devsterman's Avatar
Bike: Charcoal '07
When in doubt, change it out! Lol. If you are worried about it at all, just do it.
post #7 of 13 (permalink) Old 11-27-2012, 09:46 AM
Razor Sharp
Bike: 2003 r6 2005 r6
If your bike has been sitting that long you should spray some lube into the cylinders while you have the plugs out before you start it. Chances are those cylinders are pretty dry.
RISKY6 is offline
post #8 of 13 (permalink) Old 11-27-2012, 09:59 AM
Lifetime Premium
mgossel's Avatar
^^^this...seems if you have to ask the question, there is probably a good chance they need to be replaced. It will give you a piece of mind if anything.
mgossel is offline
post #9 of 13 (permalink) Old 11-27-2012, 12:03 PM Thread Starter
What spark plugs do u guys recommend? And where can i get the cyclinder spray at risky6? Im riding it daily now so i want to make sure everything is working properly. Thanks all
post #10 of 13 (permalink) Old 11-27-2012, 12:50 PM
Stunt Rider
ridick_bowen's Avatar
Bike: R6/R1 Hybrid
OEM parts brah.
R6/R1 hybrid
ridick_bowen is offline
Spark plug tip question Streetbikestunta Garage / Mechanical Help 2 05-29-2009 12:49 AM
Spark plug tip question Streetbikestunta Garage / Mechanical Help 0 05-29-2009 12:04 AM
NGK Spark Plug QUESTION!!!!!???? J.DenhamR6 Exhaust and fuel delivery 1 06-12-2008 02:32 PM
spark plug question blue_hulk05 Garage / Mechanical Help 1 04-24-2008 09:16 PM
spark plug question... specialblend27 General Discussions 6 07-15-2007 07:31 PM
HTML code is On
