Does anyone know if it's a straight swap to put a 2000 rear wheel/rotor/caliper setup into a 03-04 swingarm? Is the axle diameter the same?
I'm doing a custom bike where I want to use the 99-02 three spoke wheel pattern but I also want to use the newer 03-04 swingarm.
How did this work out for you? i am trying to do the exact opposite where I want to put the 2003+ 5 spoke wheels on my 2000 R6 swing arm and curious if it will be a direct fit? If not can I swap out the 2003+ swing arm onto a 2000 frame and make using the 5 spoke wheels an easier conversion? What about the front wheel are the 2003+ 5 spoke interchangeable with the stock 2000 3 blade wheels? Any in put from your project and what you experienced will be greatly appreciated. Thanks,
Related Threads
3.1M posts
112.1K members
Since 2003
