How to: install brake pads - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 17 (permalink) Old 12-02-2009, 11:53 PM Thread Starter
^^ tallest Yamaha rider^^
killa kali's Avatar
Bike: 2004 R1
Re: How to: install brake pads
Originally Posted by daobn24 View Post
Not to take anything away from your write-up but that seem like a lot of work for pads. I'm not sure if the 08-09 brakes are any different then the 06-07 but I can change my pads out in 5 min. tops. Just remove the cotter pins, the pad retainer piece and the stock pads should slide right off...
i was changing different company brake pads, so it's recommended that you sand or resurface your rotors to get that old brake pad residue off. also, my calipers were filthy and i wanted to get all that brake dust and dirt out of the pistons. I'm just extremely OCD when it comes to the bike
killa kali is offline
post #12 of 17 (permalink) Old 05-18-2010, 04:39 PM
Bike: 03 r6 and a Superduke 990
is this the same process for an 03 r6???? thanks so much
mibe is offline
post #13 of 17 (permalink) Old 09-19-2012, 08:07 AM
verybigtiter6's Avatar
Bike: 2009 r6, 2012 cbr 250
what happened to the pics???
verybigtiter6 is offline
post #14 of 17 (permalink) Old 09-19-2012, 09:12 AM
Nom Nom Nom Nom
If you're just doing pads and not resurfacing/sanding your rotors you can skip steps 4-7 and 11. There really are only two bolts that hold the calipers to the forks and the cotter pins, it's really simple if you take a look at your calipers. Here's a shot of the calipers the two hex bolt safety wired to each other top/bottom are the caliper bolts.
ChouDawg is offline
post #15 of 17 (permalink) Old 12-17-2012, 01:46 PM
Me and my Yellow R6
jinsungmin's Avatar
Bike: 2008 Yamaha R6L
Images: 2
what happen to the pics ? gone ? usually how long does a set or pads last ? with normal riding conditions ?
jinsungmin is offline
post #16 of 17 (permalink) Old 12-17-2012, 02:27 PM
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
Long time. I've got 15k on mine
Go fast parts:
, Shorai battery.
Body:
Support the forum Vendors
bryan j is offline
post #17 of 17 (permalink) Old 12-17-2012, 03:49 PM
Nom Nom Nom Nom
Ditto, I swapped mine out at 10k or so and they had a ton of life left. I think race pads or similar will have a bit shorter life span in exchange for performance. But then again, even on the track I never mash my brakes hard enough to endo or lock up the rear. Your mileage might vary in my opinion depending on how hard you are on the brakes.
ChouDawg is offline
Replacing Front Brake pads P5yk0t1c Garage / Mechanical Help 3 03-25-2008 11:43 AM
Brake Pads racer37 General Discussions 17 11-01-2007 03:03 PM
Front Brake Rotors, Brake Pads BustemUpBob General Discussions 3 07-27-2005 08:41 AM
Brake Lights Stay on After Fender Elim Kit Install midnight General Discussions 5 11-26-2004 04:05 AM
