How to: install brake pads - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 17 (permalink) Old 11-08-2009, 07:12 PM Thread Starter
^^ tallest Yamaha rider^^
killa kali's Avatar
Bike: 2004 R1
Haven't seen any detailed how-to's on brake pads, so i figured i'd throw this up. I'm installing Carbone Lorraine SBK5 brake pads (from motomummy.com) on my 2008 R6 (non S). Alright fellas this is my first write up, so bear with me
This is by far on of the easiest mods / work i've done to my bike yet
Stands are not necessary but they make the job easier
1. first things first -- the tools necessary to complete the job
- 6mm Allen wrench(T-handle and L-key)
- Ratchet (12mm socket, 7/8 socket)
- Zip ties
- Simple Green
- Spray Bottle (water)
- tooth brush
- pliers
- shop towels
- sand paper
2. Take off each Caliper (12mm socket) by unscrewing the two bolts on the back of the caliper.
3. Run a zip tie through the caliper and hang them on something (i used my frame slider) so that there isn't any stress on the brake lines.
4. Next, remove the front wheel...loosen the 2 allen bolts (6mm) on each side of the wheel. this is where you want to use the L key (for the inside bolts) it's alot easier to loosen the bolt with the L key
5. Unscrew the big bolt that is holding the axle in place (7/8 socket)
6. Push the axle out and brace the wheel -- remove the wheel
7. Not a necessary step but i chose to do it: take some heavy grit sand paper and sand your rotors to remove the old brake pad residue
8. Time to remove the old brake pads. Grab your pliers and remove the two cotter pins that are on each side of the brake pads. Push the rod out of the caliper and remove the old pads.
9. Next, i cleaned out my calipers. Get your simple green, tooth brush, spray bottle, and shop towels ready. Grab your caliper and spray the simple green all on the inside of your caliper, let it soak up a bit and then grab your tooth brush and scrub away. once you're done scrubbing, take your spray bottle filled with water and spray the calipers down. Dry them thoroughly with your shop towels
much cleaner
10. Now we put the new brake pads in. Grab your pads, line them up in the caliper. Push the pistons back into place so that they fit easily over your rotors. Put the rod through the calipers and brake pads, then put the cotter pins back in. Hang your calipers back up
11. Install your front wheel. Line your wheel up and insert the axle through the wheel. tighten up those two allen bolts on each side and torque (67ft. lbs.) that massive bolt back through your axle
Not necessary, but i greased my axle before i reinstalled the front wheel.
12. Gently install the calipers over your rotors and bolt 'em back up.
13. Pump up the brakes with your lever and off you go...slowly scrub/break the new pads in on the street
hope that wasn't too complicated
killa kali is offline
post #2 of 17 (permalink) Old 11-08-2009, 07:55 PM
Nom Nom Nom Nom
Re: How to: install brake pads
Great right up, I've heard you need to resurface the rotors before introducing new pads of different brand/compound but I think you're sand paper method is better then nothing. How many miles would you say you can get out of stock pads?
ChouDawg is offline
post #3 of 17 (permalink) Old 11-08-2009, 08:01 PM Thread Starter
killa kali's Avatar
Bike: 2004 R1
yea i heard about the resurfacing as well, but i was told by a couple track heads that sanding is sufficient enough *shrug* i've got 12K miles on my stock pads and there's still a SHIT LOAD of pad left...not even close to the wear bar (indicators)..but i wanted better braking
post #4 of 17 (permalink) Old 11-08-2009, 08:15 PM
STOP riding the BRAKES!
CoRNDoG R6's Avatar
Bike: '07 R6
Great write up!!!
Should come in handy someday!
Did you also replace the rear brake pads, if so, were they Carbone Lorraine SBK5 as well? All the site's ive seen just sell the top brand pads for the front and not the rear. Just wondering!
.:2007 R6 TOTALED:.
CoRNDoG R6 is offline
post #5 of 17 (permalink) Old 11-08-2009, 08:52 PM Thread Starter
killa kali's Avatar
Bike: 2004 R1
thx corndog
i didn't bother replacing the rear cuz i never use it
but motomummy does sell the carbone lorraine rear brake pad
post #6 of 17 (permalink) Old 11-09-2009, 05:03 AM
My R6 eats you.
Dieselboy's Avatar
Bike: 2010 Yamaha M1
Images: 1
Very nice, I'll add this to the how-to list.
Colin #686
NESBA A | CCS AM
///If you ride like lightning, you’re gonna crash like thunder.
Dieselboy is offline
post #7 of 17 (permalink) Old 11-09-2009, 08:30 AM
Noobie
Bike: 03 R6 Candy Red
Yup, the Hayne's Service & Repair Manual also tells you that you can sand the rotors with sand paper as long as the rotors are not warped. If they are warped, its recommended to get resurfaced or get new rotors lol.
drk-syd is offline
post #8 of 17 (permalink) Old 11-15-2009, 10:18 PM
RRR
Do Work
RRR's Avatar
Bike: 2007 Gsxr 750
Images: 5
Good write up man... Maybe I'll buy some new brakes lines and pads!
RRR is offline
post #9 of 17 (permalink) Old 11-15-2009, 10:22 PM
wags06R6's Avatar
Bike: Bikeless
I'll have to find the new updated one and save it I was gonna ask if someone would add this to it
wags06R6 is offline
post #10 of 17 (permalink) Old 11-15-2009, 10:36 PM
Twist the Wrist
Bike: 2006 R6 raven
Not to take anything away from your write-up but that seem like a lot of work for pads. I'm not sure if the 08-09 brakes are any different then the 06-07 but I can change my pads out in 5 min. tops. Just remove the cotter pins, the pad retainer piece and the stock pads should slide right off...
daobn24 is offline
Replacing Front Brake pads P5yk0t1c Garage / Mechanical Help 3 03-25-2008 11:43 AM
Brake Pads racer37 General Discussions 17 11-01-2007 03:03 PM
Front Brake Rotors, Brake Pads BustemUpBob General Discussions 3 07-27-2005 08:41 AM
Brake Lights Stay on After Fender Elim Kit Install midnight General Discussions 5 11-26-2004 04:05 AM
