How to: 2008 Spark Plug Change (Airbox Method) - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 102 (permalink) Old 05-20-2010, 11:27 PM Thread Starter
Make noise.
StockBiker's Avatar
Bike: The kind with pedals...
So, I was looking around and saw a number of threads that had suggestions as to how to change spark plugs, but it still seemed as though there were a number of questions that kept coming up. I decided to take pictures while I changed the plugs on my '08 to hopefully help guide others who want to attempt this task. IMHO, the airbox route is the cleanest way to do it (as opposed to the radiator route, which really is only good when you are changing your coolant anyhow), and it really isn't that hard. If anyone has any suggestions, or if I missed anything, please feel free to flame the piss out of me!
Tools: For this job, I used the following:
4mm Allen key
5mm Allen key
#2 Phillips-head screwdriver
3/8-inch ratchet
3-inch socket extension bar
10-inch socket extension bar
3/8-inch universal joint
5/8-inch spark plug socket
long-nose vice-grip pliers
O-ring pick
Spark plug gap gauge
Torque wrench
All-in-all, this was about a 4 beer job.
Step 1: Remove the seat (hopefully no picture is needed for this step)
Step 2: Remove the plastic, tank-side panels (one Phillips screw per, then slide forward).
Step 3: Remove the three Allen-head screws securing the tank (2 on the sides, one on the front) with the 5mm Allen key.
Step 4: Lift the tank and disconnect the breather tubes from the bottom of the tank.
Step 5: Disconnect the two wiring plugs and fuel line from the bottom of the tank (have a towel handy, there will be a little fuel in the line).
Step 6: Remove the pivot bolt at the back of the tank with the 5mm Allen key, and remove the tank.
Step 7: Remove the 11 Phillips-head screws from the perimeter of the airbox and lift the top half off and to the rear (rest it where your tank would be).
Step 8: Loosen the 6 Allen-head screws from around the velocity stacks using the 4mm Allen key, and the 2 Phillips-head screws holding the YCCI unit on.
Step 9: As you lift the bottom of the airbox out, disconnect the breather tube using the vice-grips (the bottom of the box seals pretty well to the throttle-bodies, so gently wiggle it loose). Place the bottom of the box with the top portion. Also remove the push-clip from the center of the intake shroud.
Step 10: Remove the plastic intake shroud to reveal the intake solenoid.
Step 11: Using the vice-grips, remove the two clips holding the tubes on and work that little sum-bitch outta there.
P.I.T.A.
Step 12: Pull back on the heat-shielding to reveal the spark plug boots. Disconnect the wire harness and, while twisting on them, pull the boots off of the plugs.
Step 13: Using the ratchet, extension bars, u-joint and spark plug socket, remove the spark plugs. Inspect the plugs for wear, adjust gap and reinstall. If you are replacing them, adjust the gap on the new plugs and install. When reinstalling the plugs, torque down to 9 ft-lbf per the manual using the torque wrench. Once the plugs are in, work through the above steps backwards to put your bike back together.
I hope this helps and good luck!
RESPECT Jason Jones
2/23/87 - 11/4/11
Drawing by me, sig by GIJoe007.
StockBiker is offline
post #2 of 102 (permalink) Old 05-27-2010, 01:00 AM
Place ad here
Weslex's Avatar
Re: How to: 2008 Spark Plug Change (Airbox Method)
Great write up bro.
Weslex is offline
post #3 of 102 (permalink) Old 05-27-2010, 01:07 AM
dont fake the funk
sill'r B sill'd's Avatar
Bike: 08 R6
thanks for the write up! will use this when installing my new plugs
It's time to kick ass and chew bubblegum. And I'm all outta gum.
sill'r B sill'd is offline
post #4 of 102 (permalink) Old 07-13-2010, 04:14 PM
lltradell's Avatar
Bike: 06R6 Anniversary ED
will this work for the 06 r6?
lltradell is offline
post #5 of 102 (permalink) Old 07-13-2010, 04:23 PM
I can ban you
Mario J's Avatar
Bike: 2013 GRB STi
Images: 3
how did I miss this? Great write up!
I <3
Mario J is offline
post #6 of 102 (permalink) Old 07-13-2010, 04:24 PM
STOP riding the BRAKES!
CoRNDoG R6's Avatar
Bike: '07 R6
Install should be the same. Great write, subscribed. Now i just have to convince myself to do it!
.:2007 R6 TOTALED:.
CoRNDoG R6 is offline
post #7 of 102 (permalink) Old 07-13-2010, 04:26 PM
COMPUTERZ
Nate D's Avatar
Bike: .........
Images: 3
Wow that is a great write up. Some one should turn the good writes up into a PDF to download.
Nate D is offline
post #8 of 102 (permalink) Old 07-13-2010, 10:23 PM Thread Starter
Make noise.
StockBiker's Avatar
Thanks guys, glad I could help.
RESPECT Jason Jones
2/23/87 - 11/4/11
post #9 of 102 (permalink) Old 07-14-2010, 07:28 AM
Lifetime Premium
2ZZ-R6's Avatar
Bike: 2008 R6
Kickass write up! I'll sure to use this!
REVIEWS:
2ZZ-R6 is offline
post #10 of 102 (permalink) Old 07-22-2010, 08:26 AM
Great job bro. Pretty crispy... r6rrdano.....
r6rrdano is offline
Anyone in LA want to help me change my spark plugs for $$? rm5063 South West 0 09-19-2008 06:26 PM
06 Spark Plug Change ussoldierforhire Garage / Mechanical Help 6 04-01-2007 01:09 PM
2004 R6 spark plug change oakesy2001uk Garage / Mechanical Help 17 09-27-2006 06:40 AM
Which spark plug is cooler? branko Garage / Mechanical Help 1 03-13-2005 02:27 AM
Oil on the threads of spark plug 008 General Discussions 1 04-10-2004 09:08 AM
