How to change fork seal - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 59 (permalink) Old 05-07-2011, 11:08 PM Thread Starter
DESE's Avatar
Bike: 09 street, 09 stunt
So I decided to do a small write up on fork seals since I couldn't find much info on them.... I just did this one today (04 gsxr) again I had to practice on a gsxr before messing with the 6, but the fork seals are the same concept...
So first thing I did is buy this video download, you also get a nice dvd in the mail, it will help a ton for $4.99.... (scroll down to basic fork service)
Then buy this handy dandy fork spring compressor for $36.95, or buy the whole kit $89.95 so the job will be super easy
So first off remove the front fairings and headlight....
Then loosen triple tree bolts, clip on bolts, brake caliper, remove front tire, then put the bike on rear stand, I used a regular jack to lift up from the headers just enough to slide the down and out...
fork out...
check preload, rebound, and bottom screw( forgot name) then loosen cap...
Drain oil then Install clip using spring compressor to access the jam nut...
Remove insides in nice neat and orderly fashion...
Remove dust cover...
Remove clip...
remove seal...
Clean very good, then use old seal to tap in the new seal so you don't damage it ( very carefully) ...
Originally Posted by tfs32 View Post
Hit some cornors at 100+ and the Armour All will just melt off....
DESE is offline
post #2 of 59 (permalink) Old 05-07-2011, 11:15 PM Thread Starter
DESE's Avatar
Re: How to change fork seal
now reassemble....
Pour in oil and bleed using the bleeding tool that comes in the kit...
Reinstall the spring...
Then put the washer and spring compressor back on...
Install washer in reverse order then cap back on...
And after you reset your preloads, and rebound your good to go...
Reinstall the tube, tighten up triple bolts.... and your good to go!
Job took an hour total, this was wayyyy easier then I though, The R6 fork is just a tad different and I will be doing mine next weekend so I will post details, the main difference is our tube doesn't come off so you need a pvc pipe to install the fork seal but same concept... I paid $250 for my last fork seal change and my cousin was quoted $400 at the dealership... he paid $20 for his seal, mine was $9.99... Total we paid $140.00 for all tools and seals, saved $510.00!!! Well worth it if you ask me...
DESE is offline
post #3 of 59 (permalink) Old 05-07-2011, 11:20 PM Thread Starter
DESE's Avatar
Ok so here are a few pics for those of you changing the R6 fork, I did this last week but didn't post it cause I put the seal backwards, but to prevent anyone else from doing it make sure you double check your seal when your taking it off, the writing should be UP and the spring DOWN!!!
Most of this is a repeat process but I hope the pics will help someone... Remove front assembly (unbolt stay, unplug wires,unbolt fairings) then wheel...
Unbolt triple tree bolts, upper tree bolts and slide out the fork tube...
*CHECK all your settings and write them on the fork or a piece of paper so you can put it back to where it was when you took it of (The video will show you how to do this correctly if you aren't sure)!!!
untwist the top cap (size unknown) and drain for a few minutes so you don't get soaked with oil when you pull it apart...
**Now I am unsure if you are supposed to set the preload all the way down before or after you remove so if anyone knows please verify so I don't give out the wrong info please
Now use the spring compressor (after setting preload down, in pic it is shown up, and you can't access it)...
Remove top cap, washer,then spring, rod, washers at the bottom of spring, and drain the rest of the fluid for 10-15 minutes....
**( this pic is shown with preload down and nut accessible,)
Remove the dust cover...
DESE is offline
post #4 of 59 (permalink) Old 05-07-2011, 11:21 PM Thread Starter
DESE's Avatar
Remove old seal...
Now when replacing new seal you can put the fork leg back on and use the PVC method to put on (recommended) or use the old seal and lightly tap the new one on, then grease the new seal before putting the tube back in...This is how the video did it so I used this method...
Now reassemble and pour in your new oil, bleed and use the fork oil tool to get the right oil level ...
After reassembling the forks make sure you put the settings back to what you wrote them down and you should be good to go....
**Sorry for the lack of pics, I planned to redo this maybe sometime this week so when I do I will make a better write up and replace this one, but this is for the people attempting this weekend if I can't get to mine
DESE is offline
post #5 of 59 (permalink) Old 05-07-2011, 11:28 PM
Adrenaline Junkie
LouisR6Raven's Avatar
Bike: 2005 R6 Raven
Great write up. Definitely worth saving a few hundred.
05 Raven
Mods:
Yoshi TRS Carbon Fiber Slip-on
K&N Air Filter
Power Commander PCIII
5000k HIDs
Black Shorty Levers
Black rear sets
Black passenger pegs
Black gas cap
Rear solo cowl
Dark smoke windscreen
Fender eliminator kit
Flush mount front signals
Integrated rear turn signals
LouisR6Raven is offline
post #6 of 59 (permalink) Old 05-23-2011, 06:07 AM
RiceBurner's Avatar
Bike: 2004 Yamaha R6
going to do my 01 r6 fork seal install this weekend. Hopefully this is relatively the same process. Thanks for the write up!
RiceBurner is offline
post #7 of 59 (permalink) Old 05-23-2011, 06:14 AM
Grrrrrrrrrrrrrr
Nick18's Avatar
Bike: 2007 R6 & 2008 R6
Awesome timing with this write up!!
2007 R6
Currently in a coma
I Need Parts!!!!
Everything from the trees forward:
Clipons, forks, lower triple and gauges
race plastics accepted also
PM me
Nick18 is offline
post #8 of 59 (permalink) Old 05-23-2011, 02:51 PM Thread Starter
DESE's Avatar
Thanks!!! The r6 fork is almost exact same, only difference is you have to set the preload all the way down to get to the jam nut, I kinda used channel locks with a lip on it, then realized how dumb I was and set the preload down and the nut is accessible ! I will put up some pics when I redo mine...Yes I said redo, MAKE SURE YOU PUT THE SEAL RIGHT SIDE UP !!! LOL !
DESE is offline
post #9 of 59 (permalink) Old 05-25-2011, 10:52 PM
RiceBurner's Avatar
ahh thats frustrating
post #10 of 59 (permalink) Old 05-26-2011, 12:11 AM
faster than a turtle XP
YZF-202's Avatar
Bike: 07 YZF-R6, 07 GSX-R 600
Send a message via Skype™ to YZF-202
nice write up and your right with saving money plus you have the tools for another time, care to help out with doing mine lol
YZF-202 is offline
Fork seal replacement, oil change, new front tire. WanaBeARacer Garage / Mechanical Help 7 05-02-2010 10:26 PM
fork seal jay2346 Suspension settings 5 12-03-2009 05:02 PM
NEED HELP A.S.A.P Fork seal KneeDragger831 General Discussions 4 05-09-2008 10:18 AM
06 R6 fork seal question, need help. KneeDragger831 General Discussions 0 05-05-2008 06:10 PM
Fork Seal Fix? ECM Suspension settings 1 05-31-2005 07:52 PM
