$5 quickshifter with PC3 USB - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 44 (permalink) Old 08-09-2011, 08:44 PM Thread Starter
Bike: 04 R1
The Dynojet quickshifter is nothing more than a momentary switch. All you need is a way to rig a switch to your shift linkage and plug it into the upper R & upper L pins on the PC3 usb expansion port.
I used an extra WOT switch from a nitrous kit.. but you can also use a pull or push type brake switch for the same result. MPS racing sells the brake sensor switch & spring combo for $15-- You'll need to fab a bracket for it though.
Ignore the green marker.. used it for mock up purposes.
To enable the quickshifter functionality in the PC software, dl & run the enable software..
I run 65ms & 15k minimum RPM for the quickshift. Be aware that the PC3 cuts fuel not spark to enable the quickshift, so if you run nitrous or FI-- cutting fuel @ high rpm can ruin your day. (my nitrous window is 9-14k rpm, shift @ 15k)
juissed is offline
post #2 of 44 (permalink) Old 08-11-2011, 08:41 PM Thread Starter
Bike: 04 R1
Re: $5 quickshifter with PC3 USB
not sure why the post isn't showing up, but I got notification of this:
Can we get a better explanation/pics of the actual shift mechanism? The PC with the right software will cut the fuel and at the same time activate the shift mechanism when at a certain RPM?
You still have to manually move the shifter with your foot. You can either load it and set the activation rpm to your desired shift point, or give slightly more pressure than loading when ready to shift. It will easily change gears @ wot with not damage to your trans. It's argued that this method is actually better for the drivetrain than using a clutch.
Its important that the switch engages just before it engages the gear change.
here are a few videos that demonstrate how this works:
This article has a good writeup about quickshifters, along with a dyno test showing a 10% increase in distance when comparing standard shifting to a quickshifter. (~1100 ft covered in 7 seconds quickshifter, ~1000ft covered in same 7 seconds on a standard setup)
juissed is offline
post #3 of 44 (permalink) Old 08-11-2011, 08:48 PM
Winter Toy, MXZ 800
MinnesotaTA's Avatar
Bike: 2007 R6
I think ill try it... I have a few extra window switches from the N20 kits from my car.. The hardest part i think is to mount it to where when u shift it hits the switch.. Then I am assuming you just plug the 2 wires into where it says "shifter" on the PCV then just set up your parameters.
-------------10.74@128 ------------------------No ET yet-------------------------------- 10.71@127 -----------------
MinnesotaTA is offline
post #4 of 44 (permalink) Old 08-11-2011, 08:51 PM Thread Starter
Bike: 04 R1
yup, order doesn't matter.
test it / program it with a low min RPM activation point. easily the best mod I've ever done.
juissed is offline
post #5 of 44 (permalink) Old 08-11-2011, 08:58 PM
Winter Toy, MXZ 800
Bike: 2007 R6
ill set it up like what u have, 65ms @ 15K.. You just made a few holes in your side guard/support and mounted your WS right?
post #6 of 44 (permalink) Old 08-11-2011, 09:40 PM
R stands for RaceBike
bruiser's Avatar
Bike: 2009 R6
would this work with the PCV too???
Speed doesn't Kill, The abrupt deceleration does.
Originally Posted by JT Money
When you wreak get inside of me
Ingredient List
Armour Bodies Track Fairings
Flash Tune ECU
K&N Air Filter
RaceTech Gold Valves
RaceTech Springs
Vortex Gas Cap
Driven-1,0 Gearing
05 header
GYTR Slip-On
Galfer Rear Wave Rotor
Green Type 3 Fren Tubo lines
bruiser is offline
post #7 of 44 (permalink) Old 08-11-2011, 09:44 PM
OhioYJ's Avatar
The R6S, or 05 earlier R6 only has 4 injectors though right?
The 06+ R6 has 8 injectors with the PCV only controlling the lower 4. While this would kill the lower 4, it won't kill the uppers meaning you will create a very lean condition (and the motor won't actually be "killed"). Ideally you always kill ignition for any sort of quick shifter, or rev-limiter to prevent lean conditions. I wouldn't recommend trying to do this on an 06+ R6.
OhioYJ is offline
post #8 of 44 (permalink) Old 08-11-2011, 09:46 PM
bruiser's Avatar
Bike: 2009 R6
ahh i see ill relay this info to my friends with pc3 tho
Ingredient List
Flash Tune ECU
K&N Air Filter
RaceTech Springs
Vortex Gas Cap
Driven-1,0 Gearing
05 header
GYTR Slip-On
bruiser is offline
post #9 of 44 (permalink) Old 08-11-2011, 11:40 PM
Winter Toy, MXZ 800
Bike: 2007 R6
it says that the dynojet quick shifter plugs into the other port.. Is it possible to get a connector and pin it in with the window switch?
post #10 of 44 (permalink) Old 08-11-2011, 11:55 PM
Lifetime Premium
franknguyen's Avatar
Bike: 07 R6
franknguyen is offline
HM quickshifter spazio10 General Discussions 43 08-26-2012 03:53 AM
How to fit a HM quickshifter Plus YK richie11 How To's... 6 03-22-2010 08:13 PM
how do you use your quickshifter? corky304@hotmail.co.uk Track Tech & Riding Techniques 1 02-03-2010 11:02 PM
Quickshifter opinions Agg2001 Track Tech & Riding Techniques 19 01-29-2010 10:24 AM
Wtb Quickshifter kbrok Bike Parts For Sale 0 03-30-2009 08:00 PM
