Adust the Idle on 09 R6 - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 13 (permalink) Old 11-23-2012, 09:48 AM
"The Dude abides .. "
MELK-MAN's Avatar
Re: Adust the Idle on 09 R6
Originally Posted by jcapstaff View Post
How do you adjust the idle or where is the idle screw located? Just curious. It does not say in the owners manual.
there is no detail on how to adjust the idle, because this bike is FLY BY WIRE, and you can NOT adjust the idle. It's programmed in the ECU.
Fly by wire.. you have a throttle cable that then turns a position sensor. That sensor sends signals to the ecu, which in turn tells the servo motors to turn the butterflys.. the butterflys are NOT turned by the cable as they are on prior generation R6 engines. If you pull the airbox cover off, with the ignition off, and turn the throttle grip, guess what? the butterflys do not move.
thus there is no way to mechanically hold the butterflys open via idle screw. And if you DO devise some way to do that, the ecu is still telling the injectors to meter out the original amount of fuel, and the A/F mix is lean.. bad for the engine.
there is likely a better and more accurate explanation in the manual, or by someone else, but this is my quick rundown of it.
do
not
mess
with
the
idle
unless
you
flash
ecu
MELK-MAN is offline
post #12 of 13 (permalink) Old 11-23-2012, 09:52 AM
Ride Safely
Marco77's Avatar
Bike: 2008 YZF R6
Flash ECU is the shit.....
by Bauce Racing AKA ChiefSmokeDawg
Marco77 is offline
post #13 of 13 (permalink) Old 11-23-2012, 09:57 AM
MELK-MAN's Avatar
Originally Posted by Tdub View Post
I didn't think it would take long before you caught that!!
i had a phone call.. LOL
need someone to take over for a few hours while i go dirt bike riding too..
MELK-MAN is offline
What should the idle be at Craig14122 Exhaust and fuel delivery 6 05-02-2010 10:13 PM
04 idle screw doesn't change the idle geeniusatwurk Garage / Mechanical Help 4 01-15-2010 10:05 AM
My first 99 R6 won't idle Whitehead'sr6 Garage / Mechanical Help 7 02-02-2008 05:08 AM
Adust idle? jc r6 Garage / Mechanical Help 9 08-26-2007 05:06 PM
Idle ? 2002r6 General Discussions 4 08-11-2006 04:45 PM
