Converting 2-wire to 3 wire Signals - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
post #21 of 32 (permalink) Old 12-10-2012, 11:21 AM
Re: Converting 2-wire to 3 wire Signals
Its a 20 watt 8 ohm resistor. I'm going to relocate the resisitors due to their weight pulling on the flushmount harness. Probably mount them up on the frame somewhere.
buzz1560 is offline
post #22 of 32 (permalink) Old 12-10-2012, 11:49 AM
Never to old to ride..
Bike: 2011 Candy Red & Blk R6
Thanks for the info. this is exactly what I needed
did you hook the load resistor to the black wire and
the other end to where the yellow wire connects
to the other two, in between the diode
gpc0722 is offline
post #23 of 32 (permalink) Old 12-10-2012, 02:20 PM
Yep that's how I wired it up.
buzz1560 is offline
post #24 of 32 (permalink) Old 12-10-2012, 05:53 PM
Perfect... Thanks very much for the help...
Cheers
gpc0722 is offline
post #25 of 32 (permalink) Old 12-16-2012, 08:22 AM
R1derr
Thanks for the awesome how-to.
kingnba6 is offline
post #26 of 32 (permalink) Old 02-03-2013, 02:11 PM
Software Developer
jp2code's Avatar
Bike: H-D XR1200 or 94 D21
OK, so let's get back onto the subject for a moment.
I want to wire up some diodes on my 2009 Harley Sportster.
Originally, I simply planned to do the relay option, until coming across this post, so big thanks to OP.
That said, I created a little breadboard with an LED, a resistor, and a diode. Connected it, and verified it worked.
I had to make big changes in the wiring diagram, because the Sportster is not quite the same as the R6 (who'd of thought? Anyway...).
The Sportster comes with Filament Bulbs, and LEDs draw much less current. When replacing filament bulbs with LEDs, load resistors have to be included or the Turn Signal Module (TSM) will detect that not enough current was used, and throw a code (i.e. Check Engine light).
I want to keep it that way, meaning I don't really want a Check Engine light; however, if I keep the load resistors in place (as shown in the attachment), they will be burning heat all of the time. I don't want that either.
How could I estimate how much current this circuit uses without the Load Resistors (in red)? Will the diodes use anything noticeable?
The LEDs I have are Rizoma Zero-11, which are rated at 13W.
Basically, I'm looking to answer a couple of questions:
  1. Is there a way to calculate if I'll need the load resistors or not?
  2. Where would load resistors need to be moved to if left on so that the circuit continues to work as it should?
Thanks,
~Joe
jp2code is offline
post #27 of 32 (permalink) Old 02-10-2013, 03:25 PM
Software Developer
jp2code's Avatar
So, I got this to work on my 2009 Harley-Davidson Sportster XR1200:
You Tube video demo:
Here is the wiring diagram I ended up going with:
My situation turned out to be a little more involved than the simple schematic the OP showed.
jp2code is offline
post #28 of 32 (permalink) Old 09-11-2013, 09:26 PM
sell me a red powerband
adamb's Avatar
Bike: 05 R6 Street, 05 R6 Track
Subbed for later, any complains with either method being too hot (hot enough to discolor or melt bodywork). Thanks!
Sent from
adamb is offline
post #29 of 32 (permalink) Old 09-12-2013, 05:02 AM
Software Developer
jp2code's Avatar
No complaints from my job!
In fact, as shown in that pic I posted above, I went from having a Load Resistor at each LED Turn Signal (4 in all) to only using a Single Load Resistor. Since I only had 1, I had more flexibility on where to install it. Finding a spot for 4 resistors can be difficult if you don't want them hanging out in the air.
jp2code is offline
post #30 of 32 (permalink) Old 05-24-2015, 08:56 AM
Hello to all. Just joined up in order to see the fotos of the wiring on the first page by the OP. But...they are still MIA. Does anyone have a link to the fotos, or maybe others, so I can see how to hook all of this up? TIA.
wgregt is offline
what is this wire? thunderzy Garage / Mechanical Help 14 01-06-2011 11:45 PM
HELP! how to wire AUDI LED to be running and turn signals! jat5944 How To's... 6 10-19-2010 06:44 PM
HELP: Installing Turn signals, mixed up wire, used wrong fuse. and now nothing works! Notn41 Garage / Mechanical Help 18 08-15-2009 07:11 PM
Fan wire up blacknight99 Garage / Mechanical Help 0 06-15-2008 12:11 AM
3-wire vs. 2-wire blinkers? besheer Appearance and Exterior Mods 11 09-23-2007 11:36 AM
