Converting 2-wire to 3 wire Signals - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 32 (permalink) Old 10-25-2011, 12:41 AM Thread Starter
ლ(ಠ益ಠლ←♫→ლ(ಠ益ಠლ
╠ Θ Wť ╣►'s Avatar
Bike: 2005 R6
Converting 2-Wire Signals to 3-Wire Functionality
This is a How-to on producing the same functionality that the front stock turn signals had, but with your new 2-wire aftermarket signals.
Here are the final Results:
The turn signal light on the Left of your screen is the Relay Option
The turn signal on the Right is utilizing the Diode/Resistor Option
This mod comes in two flavors:
1. Relay Option – This keeps your running light at full brightness and the light blinks on/off when the turn indicator is activated.
2. Diode/Resistor Option – This keeps the signal dimly lit, flashing at full brightness when the turn indicator is activated.
What you will need:
Soldering iron, resin core solder and flux. Electrical Tape. Wire Cutter/Strippers. 30 minutes.
Relay Option:
(12V, 1A Relay)
Diode/Resistor Option:
(1N4001 Rectifying Diode)
(470Ω Resistors)
Electrical Schematic of Relay Option & Diode/Resistor Option :
Electrical Schematic of relay:
Step 1: Cut 3 wire OEM turn signal lead, NOT THE HARNESS!!
Step 2: Cut the 2 wire aftermarket turn signal lead.
Step 3: Prep the wires
Step 4: Wire according to the schematic
Final Result of wiring on Relay Option: Note both grounds (black) are soldered on the same post. Also one on the relay posts is left floating.
Final result of wiring on Diode/Resistor Option: (Solder these first, you can twist together prior to soldering if needed)
Step 5: Insulate the exposed metal surfaces with electrical tape
I personally decided on going the Diode/Resistor Option but kept the relays in case I want to change it.
Enjoy
Originally Posted by clothbottom:∙
Hi,thanks for sharing the information here but I don't have a bike.
╠ Θ Wť ╣► is offline
post #2 of 32 (permalink) Old 10-25-2011, 05:26 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: Converting 2-wire to 3 wire Signals
ChiefSmokeDawg is offline
post #3 of 32 (permalink) Old 10-25-2011, 06:54 AM
Will work for track time
redwood650's Avatar
Bike: An orange one
Nice work!
redwood650 is offline
post #4 of 32 (permalink) Old 10-26-2011, 07:34 AM
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
On my GF's 09 R6 her new (two wire) LED front signals came with two wiring diagrams. One if you wanted them as running lights and blink for the signals like the stock bulbs, and the other if you wanted them off all the time and just blink when you signal.
We hooked them up so they run all the time and blink when you signal like the stock bulbs. No resistors, diodes or relays were required and they run at full brightness/12v (as measured on my multimeter)!
I'll see if I can find the wiring diagram, but maybe it's different on your 05!?
-Jamie M.
toysareforboys is offline
post #5 of 32 (permalink) Old 11-19-2011, 06:29 AM
Lovin the R6!
A7xschecter6661's Avatar
Bike: 2003 Flame Raven R6
-Jamie M.
Same here when I put my 2 wire flush signals on my 2003.
I hooked it up one way and grounded and the positive wire in one slot and they came on all the time.
So I was like wait that's not right.
Then I switched to the other and they were off and came on for signal.
Then I was like wait a second, I want them on all the time and then to signal!
And switched them back.
Now I got some nice running lights/turn signals.
Love it!
Sig thanks to Ramm
2003 Flame Raven R6 Modifications: Yoshimura RS-3 Carbon Fiber Slipon...BMC Air Filter...Power Commander III...Shogun S5 Carbon Fiber Sliders and Spools...Yamaha Velocity Stacks...Dunlop Q2s...5000k & 8000k
HIDs...GYTR Carbon Fiber Exhaust Hanger...Solo Seat Cowl...Black OEM Windscreen...Black Levers...Euro Key...Motodynamics Integrated Sequential Taillight...Flush Signals...R6 Cutout Fender Eliminator...Red Wheel tape...Black Powder-coated Rearsets
A7xschecter6661 is offline
post #6 of 32 (permalink) Old 11-19-2011, 07:55 AM
Bike: 07 R1
Bike looks great!! My GF wants me to ditch her running lights and convert them back to blink only cause the colour doesn't match her new devil eyes and angel eyes
lol.
Will try and write down the wire colours when I do it later today.
-Jamie M.
post #7 of 32 (permalink) Old 11-19-2011, 08:10 PM
Lovin the R6!
lol.
-Jamie M.
Ehh doesn't really matter. The colors were different on both sides.
If it doesn't do what you want it to the first time, try the other wire
Sig thanks to Ramm
post #8 of 32 (permalink) Old 01-04-2012, 03:37 AM
Snakebyt's Avatar
Bike: 05 Raven
good how-to, i think i might do this on my 05
Ive got more chicken strip that Dairy Queen
Snakebyt is offline
post #9 of 32 (permalink) Old 01-04-2012, 07:01 AM
R6
cbrewer323's Avatar
Bike: 2006 R6 RAVEN
lol.
-Jamie M.
My Gregg's turn signals are red.
cbrewer323 is offline
post #10 of 32 (permalink) Old 01-05-2012, 11:46 AM Thread Starter
ლ(ಠ益ಠლ←♫→ლ(ಠ益ಠლ
╠ Θ Wť ╣►'s Avatar
Bike: 2005 R6
-Jamie M.
I see what you're sayin.
what is this wire? thunderzy Garage / Mechanical Help 14 01-06-2011 11:45 PM
HELP! how to wire AUDI LED to be running and turn signals! jat5944 How To's... 6 10-19-2010 06:44 PM
HELP: Installing Turn signals, mixed up wire, used wrong fuse. and now nothing works! Notn41 Garage / Mechanical Help 18 08-15-2009 07:11 PM
Fan wire up blacknight99 Garage / Mechanical Help 0 06-15-2008 12:11 AM
3-wire vs. 2-wire blinkers? besheer Appearance and Exterior Mods 11 09-23-2007 11:36 AM
