Any How-To's on swapping the rear shock? - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 13 (permalink) Old 09-19-2012, 05:19 AM Thread Starter
Mr. Azim's Avatar
Re: Any How-To's on swapping the rear shock?
Originally Posted by natedogg624 View Post
With these long winters up here, i foresee me modding the rear end to allow for easier shock swaps...
what a pita.
Finally did this last night.... didn't have the patience to take photos and whatnot. First time doing it so it took WAY longer than it should (and not as easy as the service manual says it is). Took a lot of "maybe if I did this..." with my brother but managed to get it out.
I used axle stands but still had to remove the rear tire, made it a lot easier/lighter to move the swingwarm around as needed. Anyway, successful install. I put a tiny smidge of silicone on the end of each bolt after torquing (I do this for all installs - except wheels - so I know if I missed a bolt or not).
Anyway, she's back in one piece and ready for next week's race weekend! THanks for the tips/advice. I'll do an FAQ next time I remove it for servicing since I had a very messy and immunodeficient set up this time.
Novice #84
2006 Yamaha YZF-R6
2013 Sponsors/Supporters
Custom Leather & Vinyl
Lightweight Brake Rotors, Levers & Guards
Racer Training & Motorcycle Accessories/Parts/Repairs
Motorcycle Parts & Accessories
Mr. Azim is offline
post #12 of 13 (permalink) Old 09-19-2012, 06:39 AM
Originally Posted by My94GT View Post
i think i read some where people cut a hole in the side of the frame or sub frame to gain access?
yes drill a hole as well as weld the nut onto the opposing side of the clevis and dog bones.
Nathan - #425 - 07 Yamaha R6
35 Motorsports, Vortex Racing, Pit Posse Motorsports, Spy Optics, Suomy Helmets, 614 Paintworx, Optimal Racing, GP Tech
Nationwide Children's Hospital/Ohio Motorcyclists for Children
The Retrofit Source
natedogg624 is offline
post #13 of 13 (permalink) Old 12-08-2012, 04:11 PM
FastForward Performance
Tdub's Avatar
Bike: Honda Z50
Shock removal/install made easy...
Either weld the nut on the stock clevis or Graves offers one ready to go.
Replace the stock bolt with an allen head bolt. Modify bolt by making it absolutely only as long as needed. When installed it should just make the end of the nut. It needs to be as short as possible to clear the frame when removing. making it an allen allows for as small a hole as possible required in the subframe.
Drill a hole in the left side of the subframe so your ball end allen can get to the bolt head.
Down to the bottom...
The first time might require you remove the muffler so you can reverse the bolts so the nuts can be accessed from the left side.
Now after the bolts have been reversed you will only have to loosen the front nut and remove the rear nut. Then push the rear bolt thru just enough so the link can swing down and out of the way.
With these mods, I can remove and replace a shock in less than 3 minutes.
Tdub is offline
Swapping a shock on an 03 R6 Fallis Garage / Mechanical Help 4 10-14-2011 05:31 PM
06-09 R6 rear shock..(yellow spring), R6 shock Joken Bike Parts For Sale 0 08-15-2010 08:54 AM
'09 R1 Rear Shock onto '03-'05 R6 Audiokid1 General Discussions 6 12-22-2009 09:09 PM
***fs: Ohlins Ttx Ya789 Rear Shock 06-09 R6 Best Shock Offered For R6**** JE824016 Bike Parts For Sale 26 06-07-2009 09:13 AM
00 R6 Rear shock outrunum General Discussions 0 02-13-2007 02:02 PM
