Switching types of brake fluid (5.1 to 4) - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 11-26-2012, 10:37 AM Thread Starter
Hi - noob here!
Just bought an 09 R6 to replace my old and tired 636. Love it so far.
Quick question though:
The guy I bought it from had put DOT 5.1 fluid in the brakes. The brakes are spongy and I'd like to bleed them. I've always used DOT 4 in my bikes. My understanding is that you are not supposed to mix 5.1 and 4.
Can I just run a bunch of DOT 4 through in order to replace all of the 5.1 that's in the system? I think I read something about using DOT 4 after 5.1 having an effect on the seals (around the brake pistons)?
Thanks,
Brian
priorityR6 is offline
post #2 of 5 (permalink) Old 11-26-2012, 11:10 AM
Rocky5000100's Avatar
Bike: 2003 Track SV650, 05 R6
Re: Switching types of brake fluid (5.1 to 4)
Yes, just run a bunch through to clear out the old stuff.
Rocky5000100 is offline
post #3 of 5 (permalink) Old 11-26-2012, 01:20 PM Thread Starter
Not to sound more noobish but should I bother to go back to 4 from 5.1 in the first place? Bike is mostly for the track. I never used to wrench on my own stuff. Just looking to learn.
post #4 of 5 (permalink) Old 11-26-2012, 01:55 PM
Yes. Get 4.
Motul RBF600 or ATE Superblue are the two best choices.
post #5 of 5 (permalink) Old 11-26-2012, 02:04 PM
Alot of people prefer the DOT4. Just be aware. DOT 3,4, and 5.1 ( NOT DOT 5) are glycol based. Where DOT 5 is silicon based. DO NOT put DOT 5 in your system. IMO mixing (even though possible) is a bad idea, do a good flush if you want to use DOT4. Some DOT 4 fluids have higher boiling points than DOT 5.1, so there are reasons why they do it. When it comes down to it, they put 5.1 in the factory for a reason, unless youre competative enough to actually feel the difference, just leave it alone
Just my 2 cents.
SlickXR6 is offline
Brake fluid Chisel24 Oil and Lubrication 29 04-03-2013 06:59 AM
Brake Fluid Glock Oil and Lubrication 6 06-22-2011 05:09 AM
Twisted front wheel, old brake fluid, and brake drag pseager Garage / Mechanical Help 2 06-17-2010 08:19 PM
How to change brake fluid/steel brake lines? r6-flame General Discussions 8 03-28-2009 05:11 PM
Brake Fluid mk_r6 Garage / Mechanical Help 0 07-13-2007 12:20 AM
