How to remove controls off handle bars.. - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 6 (permalink) Old 10-12-2015, 11:12 AM Thread Starter
Exclamation How to remove controls off handle bars..
so i was involved in an accident on my 2005 r6 and replacing my handlebars with vortex ones. i can install the handlebars just fine. its getting the controls off the old handle bars im having issues with. i removed the bar end on the right side (handbrake side), but the grips wont slide out and neither will the throttle control. i have also almost stripped the bar end with the hex tool on the left side because it is completely stuck and wont bother loosening up. i almost want to saw off the old handle bar on the opposite end to remove the controls on the clutch lever side because i have new handle bars. any tips? please provide me with step by step instructions on how to remove these controls with possibly pictures. this has become a bitch to do... thank you!
Mathias05R6 is offline
post #2 of 6 (permalink) Old 10-12-2015, 11:25 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: How to remove controls off handle bars..
Use an air hose to shoot air under the grip while pulling it off. Otherwise, cut the grip itself off with a knife. The rest is really straight forward
ChiefSmokeDawg is offline
post #3 of 6 (permalink) Old 10-12-2015, 03:04 PM Thread Starter
i can get the grips off, its taking the actual controls off of the old handle bars and placing them on the new ones im having difficulties with. the grips arent too much of a concern.
post #4 of 6 (permalink) Old 10-12-2015, 03:18 PM
Bike: 2007 r6r
May be a stupid question... but are you unscrewing them? My 07 controls have little posts within the control that goes into a hole in the bar. It keeps them from spinning or sliding around
Shooshbug is offline
post #5 of 6 (permalink) Old 04-21-2017, 02:41 AM
IguezzR6's Avatar
Bike: 2008 R6S, 2014 Harley
Garage
As far as the bar ends go. I had the same issue with my left bar end. Had to break out the torch and put a little heat on it. Pour some water on the bar end to cool it and turn with a pipe wrench. Breaks it loose every time.
IguezzR6 is offline
post #6 of 6 (permalink) Old 04-21-2017, 05:44 AM
~C@TcH mE iF U c@N~
tones160's Avatar
Bike: 05 R6 - Cherry
or you can say "Open sesame!" and it comes off automatically...jk jk...when you mentioned stuck..are you able to at least rotate them? If thats the issue, a little bit of WD40 and a screw driver should do the trick....unless you already got the controls off.
tones160 is offline
New handle bars alexg Garage / Mechanical Help 3 06-20-2013 02:36 PM
How to put on new handle bars blackjack24 How To's... 11 12-17-2012 06:18 PM
Replacing Handle Bars avarda67 General Discussions 1 03-16-2012 12:39 PM
WTB- Choke lever on handle bar controls fordman03 Bikes + Parts + Gear Wanted 0 09-04-2009 09:59 PM
bent handle bars...??? 05yzf-r6 General Discussions 5 06-26-2005 01:05 PM
