06 R6 Clutch Install Problem!! - Yamaha R6 Forum: YZF-R6 Forums
 3Likes
  • 2 Post By TurboBlew
  • 1 Post By Flyers28
post #1 of 6 (permalink) Old 05-19-2017, 08:59 AM Thread Starter
So after replacing my clutch i've run into a huge problem. I tried starting my bike in neutral and it wouldn't start, almost sounded as if the battery was dying. Also the clutch cable arm seemed to be moving every time I pressed the starter which freaked me out. I tried starting the bike with the clutch in and it started, but there was this weird clicking noise and as soon as I let go of the clutch a little the clutch cable arm started snapping violently. After that, I decided to retrace my steps to find out where I went wrong. Turned out the pressure plate screws weren't torqued down enough and the entire assembly was a mess. I replaced the screws and the springs, and torqued them down, and got everything back on but I'm still having the same problem. Should I just accept the L and drop it off at a shop? I really dont know what else to do.
crmlee96 is offline
post #2 of 6 (permalink) Old 05-19-2017, 11:14 AM
Flyers28's Avatar
Bike: 07 Candy Red R6
Re: 06 R6 Clutch Install Problem!!
Are you sure your installing the clutch cover correctly with the arm as it should be per the service manual?
Flyers28 is offline
post #3 of 6 (permalink) Old 05-19-2017, 11:50 AM Thread Starter
Yea the arrow was lined up with the dot. I'm thinking I may have misaligned the pressure plate. I'm trying to remove the pressure plate now, but the flywheel keeps moving with it.
crmlee96 is offline
post #4 of 6 (permalink) Old 05-19-2017, 12:50 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
if you were actually able to fit the cover back on it 1 or 2 tries... you ****ed up.
Ive done a couple hundred motorcycle clutch jobs and that gear arm is infruiating.
You have a 1 in 6 chance getting the pressure plate on correctly.
HIS OWN 6 and Flyers28 like this.
TurboBlew is offline
post #5 of 6 (permalink) Old 05-19-2017, 04:30 PM
Flyers28's Avatar
^hahaha so true. When he said he had to open it back up and not a single string of curse words followed I knew something was off
TurboBlew likes this.
Flyers28 is offline
post #6 of 6 (permalink) Old 05-19-2017, 04:41 PM
Mr. HER6
HIS OWN 6's Avatar
Bike: 08 R6, 15 Ninja300
Did you try it with the transmission in gear? It should be pretty easy, the torque on those bolts is fairly low.
HIS OWN 6 is offline
Clutch Install Problem Takeiteasee General Discussions 6 02-01-2016 04:34 PM
clutch install problem jackalope Garage / Mechanical Help 28 12-24-2012 07:31 PM
Help please., clutch install denucchi General Discussions 4 05-12-2012 12:37 PM
Aftermarket Clutch lever install problem F4MOU$ Appearance and Exterior Mods 9 01-18-2012 12:41 PM
Clutch cover install ??? chriscon13 Garage / Mechanical Help 1 07-23-2008 02:50 PM
