How to shorten exhaust?? - Page 6 - Yamaha R6 Forum: YZF-R6 Forums
post #51 of 59 (permalink) Old 05-05-2012, 09:11 AM
Re: How to shorten exhaust??
if ur looking at the bike do u take off the end cap to the left an cut or do u take off the end cap to the right where it mounts to ur mid pip an cut......
cole steward is offline
post #52 of 59 (permalink) Old 05-24-2012, 08:27 PM
Jaguilar513700's Avatar
Originally Posted by Atcr1 View Post
Done it to several R1's including my own, My R6 and a buddies GSXR, all came out stellar
R6 looks clean do you have a video of the sound?
Jaguilar513700 is offline
post #53 of 59 (permalink) Old 07-16-2012, 10:05 PM
I always wondered about shortening the slipon. But I wanted to know if it has any adverse effects on performance?
williamluke is offline
post #54 of 59 (permalink) Old 07-27-2012, 08:08 AM
Keep Calm and Chive On!
Adverse affects on performance can very with how you actually mod the can. I just did this mod and without PCIII I lost power on my low and mid range. Top end seems to be, maybe, slightly better. Remember, this is not an engineered can, and if you start reading into back pressure and air/fuel mixtures, apart from a cheap decent sounding mod, this is very primitive to a two bros, yosh or leo slip-on.
With PCIII you can correct the changes in back pressure by altering the air/fuel mixtures. PCIII offers preloaded maps for different slip-ons so you will have to find one that gets close. A custom tune on the dyno will do this properly and is the best recommended option to properly adjust for any mods you do.
I have found with PCIII thus far - since I haven't been able to get dyno time, the Yoshi Slip-on with aftermarket or stock air filter pre-loaded PCIII map has been the best.
Bottom line, if you do cut the stock can down there are two things to consider performance wise. You don't want to run too lean of a fuel mixture because you could burn the exhaust valves and you most likely will lose some power on the low and mid range until you can get a custom tune.
Skitch is offline
post #55 of 59 (permalink) Old 07-27-2012, 08:44 AM
Caution: CAUTION!
tobimaru's Avatar
Previous owner chopped the Yosh on my old '02, pretty short too. I actually really like the look and sound. It was loud.
tobimaru is offline
post #56 of 59 (permalink) Old 12-07-2012, 05:44 PM
I cut down my stock exhaust using a lot of the info I found on here. I cut off 9" and painted the can high-temp flat black with gloss black on the end caps. Sounds 10 times better than stock, and looks pretty sweet too! What do you think?
jpking is offline
post #57 of 59 (permalink) Old 12-08-2012, 07:35 AM
r6sport's Avatar
Bike: 2006 Yamaha R6S
I love it! I need to get mine done! I'm so lazy!!
r6sport is offline
post #58 of 59 (permalink) Old 12-08-2012, 07:44 AM
Stunt Rider
ridick_bowen's Avatar
Bike: R6/R1 Hybrid
I do whoolies to shorten my stock exhaust. So far I've managed to scrape down an 1".
Sent from my SCH-I535 using Motorcycle.com Free App
R6/R1 hybrid
ridick_bowen is offline
post #59 of 59 (permalink) Old 12-08-2012, 12:20 PM
QR6
PHX-602
QR6's Avatar
Bike: 2007 R6
Images: 6
Looks good man. I painted mine the same way on my 07 R6r. For sale now in classifieds.
Quintin - 2007 Street to Track & Back R6
ASMA #26 early retirement
My build thread:
QR6 is offline
Product Review: Bruce Fabrication Exhaust DvlRacer Product Reviews 31 08-31-2010 11:07 PM
Cops Banning All Loud Exhaust Over Here!!... GET CARTER General Discussions 40 04-02-2009 10:50 PM
No Exhaust Kelm Exhaust and fuel delivery 32 06-05-2008 07:38 PM
Need Exhaust Expert for Info!!!! My01R6 Exhaust and fuel delivery 0 07-07-2006 10:17 PM
